Hi, I have a problem with my car overboosting and causing it to knock
here is my set up
GCG HF/BB
555 HKS injectors
Pro spec B2 B/C
FMIC
it was set to 15psi high boost and 10psi low boost on the dyno
on the road high boost climbs to 17.7 psi and low to 12.2psi low
my boost controller on high is set at
gain 15%
set gain at 50
the over boost cause to knock after 6000rpm
any ideas why
cheers
joe
https://www.sau.com.au/forums/topic/192179-overboosting-knocking/
when my m8s car was on high boost it started knocking at high revs... then at most revs... then at all revs... the knocking getting worse and worse... turned out he had done a big end bearing. probly nothing this major in your car just a thought thats all
running power FC
had a knock reading of 94
on the dyno it showed a nice straight line at 15psi at peak getting 252rwkw
Take it to your tuner and get him to adjust the tune - it's not a matter of adjusting the boost controller, esp considering on a freezing night you'd be likely to get a spike again anyway... rather you should try to ensure the tune is better...
So speak to your tuner :ninja:
this is been an ongoing problem on dyno its sweet on the road in spikes even with the boost contoller of it boosts to 12psi
even with a perfect EBC it'll still spike a bit - I'm surprised your tune is so close to the limit that a tad more boost causes knocking. Why not richen up the tune (or take out a tad of timing) a little so at least you can drive the thing properly whilst identifying your issue :ninja:
Edited by TommO
Thanks everyone, its really fustraiting me I had the spike problem with it before, i was informed that the OP6 housing will fix it. but im back to square 1
I'm to the tuner 2moro
if i get them to tune
13psi high boost do on the road i should get 15psi
8 psi low road 10psi
maybe that will work
why don't you just have one tune at one set boost, and control the power with your foot?
I have one tune running 300rwkw and 18psi of boost.
When I want half power, I use half throttle?
Edited by The Mafia
how do you do that when its on man.. all you wanna do full throttle and punch the gears,
how do you get 300 stock engine no knock
a decent tune.
I ran 370rwkw, no spike, no knock.
Its a combination of things.
Plus your running a PFC - so you cant have two maps unless your running a datalogit and change it everytime you change boost setting.
Power/boost is controlled by the right foot. I ran 24psi daily without issue
a decent tune.
370rwkw with the RB25?
Sounds like a handful lol
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
