Spotted - QLD Skyline Owners
locutus_of_bris
Hey yotis, I used to live around the corner from you, everyday id go past ya 34 at least 2 or 3 times and admire it, moved to Ormeau now though, although I still work in Helensvale so keep an eye out for my 32
By the way, I remember driving past your car on Helensvale road and seeing it all messed up, I shed a tear
Does anyone know a White 33 GTST with a 400R front and big GT-wing around the Sinnamon Park area. Seen it a couple of time now. Looks pretty sweet I always see it when I am in the mini though. :)
And to a White 180sx and Dark (black I think) R32 GTST from the same area, tailgate me like that again and I will flog you! I am sure the other three cars you nearly ran off the road down the centenary hwy feel the same way. Wankers, you give our cars a bad name.
Seen a 32 GTR at KP maccas late last nite, and Greg/zoixy on the way back, looked like you had a good nite mate :P i was buggered, was out for a mates bday
dunno if you saw it, but an xr8 ute wouldnt leave me alone coming off the story bridge, we had a go and he wasnt happy, almost didnt make the corner going past you, he had to lock up
Hey all
Also just bought a skyline, finally.
For those of you who know WADOS.
i bought his R32 Gts-t
IT's wine red with s15 stock wheels and GTR front bar
so if you c me around dont be SHY &
let me know of any cruises and stuff thats on.
cheers
Chris
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
