Gunmetal greay R34 sedan, NSR34, on the M Northound, he took the redland bay exit, I waved and waved, but the oldish looking fellow did not even glance sideways.
Was a very clean looking R34 too!
Spotted a yellow r33 driving down my road, thought it might be Col so waved, and waved and waved then just as I was about o pass him he waved, dunno if it was col or not though, but meh spotted! :D
I saw Drew at northfield car souns r34 gtr today, and low and behold, northfield car sound!
that shouldnt count
his r34 is always there
also, i thoguht it was a gtt
drew is a total champ and has looked after my car stereo needs for the last 10 years or so
that shouldnt count
Hes got a gtt too... and the ute... and the mini van...
The GTR he has only had for a few weeks I think.
anyway tonite on the 'way' down the 'coast' we saw numerous skylines, mostly black or maroon R33s.
See attached for the reason of why we saw so many. We were on the side of the road waiting for a tow truck. It sheared off 6 bolts, we were in 4th, with only 6psi, and a max rpm of 4500... I now know why I went for a RWD nissan, not a FWD toyota :huh:
HAHAHAHA
Thats my old man. And he says he not an oldish looking fellow hes still a young man.
Thats old age for ya cant see s**t
he siad he will look over next time.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
