Spotted a few on the weekend.
Silver 33 heading towards nerang on sunday (on hooker blvd/Nerang Broadbeach Rd)
Saw a white 33 in Coolangatta,
Also drove down some backstreets at coolangatta/tweed (just off Kenedy Drive) and saw a house that Had 2 skylines parked beside it.
also see a maroon 33 s2 with maroon rims around tweed/coolangatta alot.
ALSO - every day, i drive past a clean white 32 in Kingscliff, thats now for sale? :thumbsup:
Edited by Sagiedaks
Spotted a few lately
yesterday afternoon i spotted a silver r34 and a maroon r33 coupes near diddilibah.
and this morning i spotted a white r33 coupe passing saint andrews drive and a speed camera.
this isnt a nissan or a skylinebut well i spotted this Confused holden barina at inala ... had M3 badges on the rear too
I hope no ones missing badges off their M3...
Also Spotted Bunta and Anna on logan road myself and Adam were trying to think whos car it was sorry we were out of our brains ...
Spotted PFC33 black S1 on logan road , Black R32 OMY32
saw a few cars out at the drags on sat anyone here go??
white 33, white 33 with a black bonnet, grey 32 and a red 33
Just to jump off topic quickly, what times were you running Mort?
Messy was trying to get me out in my line but I had other plans.
And poor Messy, snapping his rockers... ouchie lol. atleast this is an excuse for him to start the headwork on the GTiR.
red clean, wingless 34 GTT sedan in Kippa Ring this afternoon...and later on a black GTT on the hornibrook bridge with kit and wheels...
same red sedan i posted pics of on the page before this? i spotted it today aswell :D
pretty shite ones actually first run was to embarrissing to mention :D but got 14.5, 14.6 and my mate got a 14.1 in her, best shes done is 13.9
mate took his GTiR out and killed it on the first run :) so far found 2 of the little arms that go to the valves pushed off and head gasket was kool
Just wondering if the dude with the Gunmetal Grey R32 from Darling Heights, Toowoomba is a member on here.
I was following behind you on my way home at about 9:20pm tonight, I came out sideways when following you into Stenner :)
Spotted turbs33 at 7-11 tonite :) also a noob in a yellow R34 coupe without a wing white 18" wheels who tried to race me in front of cops ... mate if your on here dont even bother its good that he got caught trying to drag..
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
