spotted around 12ish today on anzac avenue on the over pass over the hhighway, a silver r34, plates weere pht34 . had a largish size person driving, i think it was a chick with a really short hair cut :P anyone on here?
just spotted outside nearmy work springhill black R33 with side crash rego 239.KKR anyone on here? if you are better move the car before the building owners get it towed.Parked on barry street springhill
Spotted a Black R35 GTR (yes thats right, R35) in boronia heights at about 11:45am driving down towards greenbank... as far as i understood these arent street driveable yet? can anyone confirm? i thought they were only for track use at present
Looked beautiful, soo nice and shiney, didnt catch the plates since i was too busy staring at the car!
if i saw one i would follow till they stopped and had a nice long chat hopefully ending in a drive
keep spotting this white, r34 with some tribal graphics on the boot, no wing. Gold Coast. you on here??
Yeah I've seen that one around heaps, with a full bomex kit + no wing. It's nice. I saw it yesterday doing laps at sufferers parasite
some other skyrines I've seen recently:
saw GTT23(silver 34) at garden city friday night
Also saw a black 33 travelling up kessells road, near the old ANZ stadium some time last week, it went pretty good. Is it anyone on here?
I saw the same one when I was on my way down Middle Rd... had many a glance to see if I was mistaken cause I didnt think there were any R35's in this neck of the woods yet.
keep seeing a white r33 along johnson road,, driven by a chick, on my way to work in the morning
always in the work car, so no point waving
That would be my line you see. Just dont look at the front bar :ninja: been to lazy to fix it up.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
