spotted Glen PNK32 on Edward Street opp the Victory last nite by the time i got towards you were gone.. was n foot , also spotted 911-GTR R32 on the M! a few moments ago was in the lancer
Spotted SPOILD R34 Coupe near gardencity today 11am
xxx-IOJ, white R33 GTS25t with what looks to be a boot lid from a GTR V-Spec (spoiler, badge and sticker), V-Spec front bar etc, a bit of other damage so suspect it's been fixed with parts from a wrecked GTR. Bad luck mate :\
Spotted white R34 with black tribals on the back...gave me thumbs up...I asked if he was in SAU....said 'nah' then I watched the show as a 911 porsche pulled up next to him...couldnt keep up though...(non-turbo 4 door 34) :whistling:
Oh....also spotted silver 4 door 34 with only front kit at 'WOW' underwood...2nd time i seen ya....
spotted a black 32, red 32, black 33 and white 34 cruising noosa parklands on the weekend. The black 32 sounded very angry blasting up 'the hill', actually they all sounded very nice. Good to see the north sunny coast boys enjoying their cars, keep it up.
R32 GT-R from Lydon Rd turning onto redland bay rd towards Vic Pt
Also at same intersection same time, R33 GTS-T with some sorta kit on it going towards capalaba, would have seen the 32 aswell.
R32 GT-R at about 9:20pm in cleveland
So many skylines around, i'm so lazy to post.
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
