Saw a nice looking R33 (110 HCT or something like that) at the roundabout on moggill road in indooroopilly. The driver turn into my lane right up behind me. If you are reading this, i did gave you a wave and i could have sworn i saw you smiled.
btw, nice wheels
GenesisR32
I'm Michael, 21Y/O and poor because of skyline payments. I drive a white 32 GTST. Engine is Stock bar pod filter, bit of suspension work though :D I toot and wave at other lines...don't always get a response.
Bryanlee, were you cruising around the city last Friday night? I was with a friend in his VK commonwhore (I was friends with him before he bought it). I think we pulled up next to you near city rowers? Pretty car ;) but if it was you it would mean that the paintwork was fixed up (ie - no bog)?
Whilst we are on the subject, who owns the Gunmetal R33 GTST that blew away that worked WRX along the Robina Parkway down on the Gold Coast last Saturday Night week?
Looks like a Mspec bodykit with Black plates (can't remember the numbers) very nice car.
Man your car is quick, that Rex has had me twice in the last week (and I usually take them) But you fed him his lunch, it was so cool, he was so pissed at the next lights cause me and my mate were laughing at him.
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
