Spotted - QLD Skyline Owners
locutus_of_bris
Took this a while ago,,
Although we're pretty much parked near eachother everyday!! :sick:
Also spotted 2nd pic in the carpark, Not a skyrice, But it was too funny not to take a pic..
spotted Cusak silver V35 on logan road you where at lights near maccers .. i was in blue 35 that beeped at you..
Spotted a stock White v35 with stickers on it driven by heels .. sadly it was a 250gt ....
This morning on Kessels road red V35 standard plates you were turning into Autobarn macgregor .. driven by a P plater ..
Spotted a white R35 GTR on Vulture St in West End. Can't tell you plates because it wasn't wearing any, not even a trade plate lol
Damn they have some presence on the road!
Spotted Mr -032 tonight at the hyperdome (Thursday night around 7pm) darkish colour. Then spotted a white r33 s1 heading south past beenleigh, had some stickers on the back and side, cant remember plates, I gave a wave.
Spotted "GTR35" at GU uni on the Goldcoast. Gave you a thumbs up, but judging from your disgusted look; R34's are just shit to you now. Hope my 35 doesn't turn me into a flamin mongrel as well
Wait wait. Didn't pass. Driver went into the park and ride carpark, well behind capalaba central carpark.
near the central busstop?
that was me i think. picking my misses up.
Pretty sure I spotted 666DAN going up sugarbag road in caloundra on saturday....I only caught a very quick glimpse, could be wrong.
Spotted a grey series 1 r33 pulling into 7/11 on vulture street as I was pulling out, sorry I cut you off a tad bro :P
Yeah, it was central stop.. gt-t went through the back... next to the community library.
Spotted MRR34 at Sunnybank Market Square....drove past me and my mate in front of Kingsfood...
Car stands out like hell with all them sau stickers, freakin hot...hope you saw my 'dulled down' version R34 parked in front of blockbuster....just call me when you wanna swap. :)
Spotted a grey series 1 r33 pulling into 7/11 on vulture street as I was pulling out, sorry I cut you off a tad bro :)
Nah wasn't me, the car actually didn't move Friday through Saturday due to my BAC not being under 0.05....I love easter long weekend!!!
spotted Owgsm over the weekend going past my house on mt gravatt capalaba road
Also spotted white r32 gtr near bryn bart ford pulled over by the coppers .. mt gravatt
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
