Spotted - QLD Skyline Owners
locutus_of_bris
Spotted Vish (Vandit) "I think" on Padstow road..flashed me which I thought was a "speed camera ahead" warning...then I remembered...gold magna + black man = Vish! lol
Spotted Johnny ! i did flash at you .. i thought i blended in with the interior ! ah well damit more spray tan i need !...
Spotted Damian R33 S2 on logan road yesterday
gts r33 at labulsa park kawana, and also a another white r33 with no spoiler and meshlike rims driven by a few times
was enjoying an ANZAC BBQ, saw another few skylines there parked also, 1 may have been you...... the other white 33 with no spoiler was parked behind my place at alex heads, personalised plates i think too
waved to a white 33 going down maud street, got a wave back
that was me on maud st bro, nice ride :down:
Edited by jimmy_james13
spotted 83CKS @ Mcwhiters car park yesterday arvo.. was so distracted i scrapped my front lip on the 35 hehe .. .. another white 34 standard plates 3 parks away from you had stickers from ADD racing and driven by heels .. sticker
Yeah I seen your car there.... I was drinking so had to get someone to drive my car home for me lol Was thinking about leaving it there but then had a change of heart! (dark park on sat night.... not a chance)
Hey Hun :)
The other 34 must of gone when i left..
What level do you normally park on??
Sammy34. Getting his fix this morning at mobile.
You got a very dark tint. Front windows. Quarters not tinted?
everything but front is tinted, yeh havent been pulled over yet but you actually have trouble seeing outside the car in daylight the tint is so dark lol.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
