Spotted - QLD Skyline Owners
locutus_of_bris
spotted a black 34 coupe in the city on ann st (with sau sticker!) about 12pm yesterday.
Thought it might have been me... then saw
Haha thanks Chris! Been dying to be spotted :thumbsup: Thanks for work done too.... very pleased! Wrong topic for it, but thanks heaps.
Then realised it was also a saturday so can't be me...
Seen plenty lately... waved at a few... just get looks back.. (And too slow to take details of number plates)
keep seeing hotties *sexy females* in R32..
one along coro drive today the other was near the airport friday morning
spotted a rough looking black 34 tonight, out near roma street at 9:45pm ish.
needs some pannel work.
would have waved, but was in the golf gti
spotted Alica R34 gtr on logan road u went past me heading south..
Also spotted a nobhead with XXXLFO plates near old cleveland road and logan cnr .. doing silly sideways action in traffic.. some ppl have too much money to burn in tyres ..
Spotted a maroon R33 along mt crosby road...I was 4 cars back, then two back driving up past colleges crossing. You turned left to Karalee or Barellan Point??? Rego was something like 969GVN
Edited by Thor250f
Spotted a Maroon R33 S2 with a big front mount. Blond chick driving but not look at the road as I passed by, This was in Labrador at about 3:20 or so.
Spotted a purple R32 on pumicestone road on the bridge over the bruce highway.
fark what are ya doing all the way up there...
Anyways, spotted Revhead on the highway heading south yesterday morning on his way to work :bunny:
Saw 00HME at the shops on Algester Rd. Was walking to the Zebra crossing into the parking lot with my two girls. They liked your car and said to me, look daddy, that one sneezes like yours :D
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
