yea I spot him all the time, he lives in my estate.
Spotted SMR33 last night as I was exiting to the freeway from Carindale...drove right past you at the lights but it as too dark to wave or anything :(
Karen says hi! :P
saw GTR R35 in the holy spirit hospital car park today! :D
as i was riding down in the lift the doors opened and like a sign from heaven there you were. and then i looked like a toss when i realised i was moaning out aloud and the others could hear me! lol lol :(
it was worth it!
Spotted JEZ42 at the Oxley roundabout today about 40mins ago. You were next to me going on to the roundabout. Unless you know my plates you wouldn't have seen me as i don't drive a skyline or a nissan for that fact anymore...
Probably wouldn't have noticed if you were in a line, spent a bit to long at HN's and was running late. :banana:
White R32 with vielside front bar at like 620am this morning on Bribie Island Rd.
Also a nice R32 GTR on Newmarket Rd at 435 yesterday arvo
Was that you at the front of pack at the traffic lights opposite the car (holden?) dealership?
turning onto Kendron brook Rd.... yeah that was me in my mates black R33.... i have a white one but didnt drive to work that day.... I work in the harrys diner complex...
i think hes on this forum... h8 tax that is.
saw two GTR's tonight, a dark blue one on alex with and 32FTW gtr... gunmetal grey with white wheel.... also lol'd at a two tone orange and black one r32
I wasnt in my car its still at the mechanic.
If the R32 was charcole gray that was I!!!
Sorry mate was white...
Also seen a nice white R32 on the way home yesterday on the highway between D'bay rd turn off and Bounardy Rd turn off.. Plates were PEK33... Seemed like a quick car when you shot down the left lane... If on here did you see the guy in the white forrester on like 20 inch chromies? i think he was trying to race anyone he saw.... and the car was gutless as =]
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
