outside dan murphys to be excact, many skyliners around the holland park area?
Ooo yes.. that would have been yesterday :whistling: We were inside .. where were you?
Hmmm not too many around hp area, I see a silver r35 with standard plates around there sometimes though :thumbsup: I think he knows someone/lives around the bp down the road near the car wash
Chris Rogers in the AE van...
About 30 minutes ago h was cruising along southpine road just after linkfield road...
I pulled up along side at 70 and waved and waved and waved... He was in a world of his own, looked like he was listerning to phil collins... ;)
Anyways I hit it and flew past in the purple people eater...
that was you!!!
wondered who the hell that was. was listen to phil collins actually :dry: lay on the horn next time.
was that you rev head??
next time i see you ill start to blow u kisses and holding signs to have my babies ;)
hehe I doubt it, not unless you mistook my bike or my daily for a Skyline lol. The poor old 'line has barely moved in the last month, hooray for work consuming all of what would otherwise be my spare time!
I pulled up along side at 70 and waved and waved and waved... He was in a world of his own, looked like he was listerning to phil collins... :dry:
Sometimes you need to be a bit more patient with the elderly...
Spotted 83CKS in The Valley carpark again!! It's amazing I think your alarm was probably the only one that didn't go off when I drove past. Was gonna stop and leave a msg, but you might have thought me a stalker so I didn't!! Looked clean.
Peace.
Spotted numerous other skylines as well....no one waved....ghey.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
