white 33 s2 heading from the m1 onto the southport exit, plates were RAS --- i was in the dark blue 33 u guys were playing with. Nice car :-) I would have played more but i realised just last night my license was expired!!
theres quite a few tidy skylines gettin round. im ty, own a black 97 gts-t r33 m spec 2 door. pretty standard apart from rims, lowered and exhaust. has splitfire coils, walbro fuel pump, k&n panel filter. im usually up n down the motorway every morn n arv. u spot it gimme a wave. 113-***
you cant do that... that's cheating. now we know what to look for and its not as fun :thumbsup:
p.s if you do get spotted your not cool anymore :D
Not a skyline but worth sharing. Spotted a green VE ute doing a U turn on Beaudesert Rd, giving abit of stick, ass end kicks out, sounded tough, followed by the death screech and mounted the medium island. bummer, can't say you didn't deserve it, keep it on the track buddy.
Lol suck shit buddy!
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
