spotted new gtr yesterday in southport mall bluey grey?
i was looking at his and he was looking at mine(no homo) :ermm:
wonder if he wanted to swap?
Well he should have bought a real Skyline in the first place then.
Spotted a silver 4 door 33 today in Hawdon St, Windsor/The Grange, and a black 34 with a white front bar drove past me while I was walking up Kedron Brook Rd.
Also a white 32 this morning sitting next to me in traffic on Webster Road... think I may have seen that car last Friday as well.
To the wanker P plater in the silver R34 this evening coming through Bracken Ridge onto the gateway highway.
I was not attempting to race you, i was running late for a function and was trying to get there on time, so racing up and then getting infront of me coming onto the highway was not you winning, also the half-arsed clutch kick on the on-ramp to the highway was not only pathetic but was also insanely stupid thing to do.
WARNING
to anyone in an skyline/ import around the broad beach area
there is a fat c/nt in a gold v8 statesman vt/vx model?
that likes to try to run you off the road im not sure why?
he sat on my arse for bout 1km then tried to pull up beside and merge into side
of me i booted it leaving him standing and turned then he was there again close enough i could not see his headlights
i pulled off onto the shoulder and he flew by swerving at me then pulled over and jumped out car waving his fists in anger :) as i boosted past :(
this guy is clearly a fu*ing idiot
he is a big fat terd wearing a blue collared work shirt very similar to a cabbie or bus drivers shirt
if you see him up your arse just get out the way
he does not appear to give a shit about his car or anyone Else's
if i did not have my wife in the car
this would of ended differently
:huh:
WARNING
:huh:
Simply pull over if it gets too much, call the police, take note of his number plates.
What you do (boot in anger) and he does can cause serious accidents.
There is every type of person out there, just need to not be sucked into the wrong crap.
yeah true
i only give it a boot to get away from the co&khead
ive only the had the skyline bout 2 months
still getting used to all the retards i guess
:P
I still haven't been spotted by anyone outside of our group :ermm:
I've spotted you a few times. There's a few others like yours that get around these parts. I saw one a while ago at the subway in albany creek, getting import checked with a late series FD
Hey,i'm on holidays up here at the mom,keep seeing a suncorp add on tv,is the car at the start of the add a 35 r ?. looks like it to me. :blink:
is it the one with the voice control and he is saying "step on it", etc and it keeps repeating the wrong thing? if so, then yes that is a r35 gtr.
next to a white 32gtr (was in my blue 32gtr)
on old cleveland rd coorparoo arount 9 pm or so near mcdonalds
It had close to mexican offset but was very cool
as usual the driver wouldent look at me (might have been searching for the lastest fixie bike?)
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
