Metallic blue 4 door 33 also spotted this afternoon heading into Supercheap at Kessels Rd.
like an hour ago?
that was me heading into trade secret for some new business shirts
You too looked so cosy sitting at the servo together i must say... :laugh:
oh where were you?? didnt see your 32 anywhere in sight... should have said hi .. i guess yellow skyline owners know whats its like :D
oh where were you?? didnt see your 32 anywhere in sight... should have said hi .. i guess yellow skyline owners know whats its like :laugh:
My 32 was parked at my house around the corner!
I was in the company car! :P
Mazda 3 lol
Spotted a carbon copy of my car yesterday afternoon on Beaudesert Road, outbound. silver R33 S2, with front mount, and SAU sticker on the side.
And then on the way back out on Beaudesert around 6pm, spotted dark 180sx with some ugly ass tail lights following another silver S2.
Was in my work camry, so didn't want to attract any attention to myself.
dam man i saw like a crap load of Skylines yesterday i cant remember exactly where... near driftking or was it all stars :laugh:
some very sex cars and some very ugly Lexus he he he J/k's
saw heaps of cars down the spit last night....don't remember all the plates and I cbf stopping. Speed bumps pwned my is200!
Weak. all of Gold Coast, Brisbane.. AllStar Tuning... M1 pwne my under body :laugh:
Sparks FTW.
Saw a few cars doing spit runs from the dyno day
Spotted Zennon's car parked in Hindes St today, I beeped as I drove past :)
Also spotted Franky on Finucane Road Alex Hills this arvo...gave/got waves :)
yeah i spotted you too. LOL!!! Wat were you doing in my neighbourhood? I was on my way to work with the father in law
I had just been over to Manly to visit my nana and was going home. My parents also live in Alex Hills, so I'm over that way a lot :)
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
