spotted Glen PNK32 on Edward Street opp the Victory last nite by the time i got towards you were gone.. was n foot , also spotted 911-GTR R32 on the M! a few moments ago was in the lancer
Spotted SPOILD R34 Coupe near gardencity today 11am
xxx-IOJ, white R33 GTS25t with what looks to be a boot lid from a GTR V-Spec (spoiler, badge and sticker), V-Spec front bar etc, a bit of other damage so suspect it's been fixed with parts from a wrecked GTR. Bad luck mate :\
Spotted white R34 with black tribals on the back...gave me thumbs up...I asked if he was in SAU....said 'nah' then I watched the show as a 911 porsche pulled up next to him...couldnt keep up though...(non-turbo 4 door 34) :whistling:
Oh....also spotted silver 4 door 34 with only front kit at 'WOW' underwood...2nd time i seen ya....
spotted a black 32, red 32, black 33 and white 34 cruising noosa parklands on the weekend. The black 32 sounded very angry blasting up 'the hill', actually they all sounded very nice. Good to see the north sunny coast boys enjoying their cars, keep it up.
R32 GT-R from Lydon Rd turning onto redland bay rd towards Vic Pt
Also at same intersection same time, R33 GTS-T with some sorta kit on it going towards capalaba, would have seen the 32 aswell.
R32 GT-R at about 9:20pm in cleveland
So many skylines around, i'm so lazy to post.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
