Spotted - QLD Skyline Owners
locutus_of_bris
spotted black r32 gtr with plates GTR-09 in logan - headin toward highway at daisy hill exit this arvo, I was in the white 33 behind u.
Spotted silver R35 "GTR 087" again today on Stanley Rd, Camp Hill - are you a local or something dude? Nice to see an R35 cruising around my part of the world.... :blush:
Spotted a LM R33 at Everton Hills :blush:
(I make it out liek it was a ninja spotting, but it was just on the side of a heavily used road... :P )
Was there last night parked on the footpath and then there again this morning... Jay## was the rego...
There has been an R35 GTR at my work almost every day if not every second day for the last two weeks (Mater Private Hospital).
First spotted about two weeks ago when my partner was pulling in to pick me up and called me telling me I better finish work quickly if I wanna see something cool and of course I had to overtime, but then it was still there when I left, and my god I want one so bad. My 34 looked so not tough sitting next to it lol
there are 2 there actually!
Edited by handbrake
Spotted silver R35 "GTR 087" again today on Stanley Rd, Camp Hill - are you a local or something dude? Nice to see an R35 cruising around my part of the world.... :nyaanyaa:
i live in camp also ive seen him a few times while im in the blue 32gtr
so awesome to see one around here
Saw a red r35 at a quarter to 3 turning from newnham road into link street in wishart (just near garden city).
Dam they look good in red!
Personal plates? Saw the same one 10 minutes later
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
