a white r34 nur spec 2? or something below the drives side rear light leaven palmwoods iga this arvo... i yelled out to ya but you were doing something with ya cd player or something... i was at the pub
Spotted in Morayfield/Caboolture...
Rather neat 34 with nice green paint with pearl through it, didn't catch plates though.
Shabby ass 33 light green with r32 gtr badge on the back.... why??
Neat silver 33 this arvo, turning in to 'boolture lakes, beepd 'em, they looked confused. :)
Spotted an r32 gt-r at the richlands courthouse. Impounded maybe?? Anyone on here own it? also spotted another r32 with the number plates 'gi joe' at monier woolworths. I was the one with the silver r33 4 door.
saw two r32's on the way to jambo today. on the m1. one pink ones with unpainted bar and skirts. PNK32 plates, and a gun metal grey one aswell.. pretty nice cars. The gun metal grey one had a SAU sticker i think.... i was in the maroon/red r32 who was with the 180sx and black r33
spotted a bunch of nice skylines on the way too/at/and on the way home from Jambo.
most obvious was 85URK, r32na (i was parked in the same row as you guys on sunday)
a white r33 with white wheels also nearby, and what appeareed to be an uber low 32gtr on stock 33 gtst wheels.
half of you prob saw me, but i was in my kombi not my skyrine (big yellow VW van thats loud and slow and covered in green sign writing) :)
spotted MYY34, watched you at willowbank raceway.......are you N/A? i had the black 34 in the parking lot with the massive GT wing lol
it was an NA auto, but she converted it to rb25det manual :)
win! :)
Followed a Silver V35 [rego xxxLJD]on Bruce highway south bound from bout boundary Rd exit till gateway turn off.. Went from Right lane to far left in one move.. Lookes nice and picked up spped quick!
also seen S1 R33 [Rego xxxFWC] at the intersection of gympie rd and Webstr rd..... Due for a clean and running a bit rich from the looks... but sounded good
Spotted a stagea on sunday morning heading south on the m1 near yatala. Think wgn34? looking good, i think it was fairly obvious i was having a good old look at your car when you passed lol i was in that shabby silver r33!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
