outside dan murphys to be excact, many skyliners around the holland park area?
Ooo yes.. that would have been yesterday :whistling: We were inside .. where were you?
Hmmm not too many around hp area, I see a silver r35 with standard plates around there sometimes though :thumbsup: I think he knows someone/lives around the bp down the road near the car wash
Chris Rogers in the AE van...
About 30 minutes ago h was cruising along southpine road just after linkfield road...
I pulled up along side at 70 and waved and waved and waved... He was in a world of his own, looked like he was listerning to phil collins... ;)
Anyways I hit it and flew past in the purple people eater...
that was you!!!
wondered who the hell that was. was listen to phil collins actually :dry: lay on the horn next time.
was that you rev head??
next time i see you ill start to blow u kisses and holding signs to have my babies ;)
hehe I doubt it, not unless you mistook my bike or my daily for a Skyline lol. The poor old 'line has barely moved in the last month, hooray for work consuming all of what would otherwise be my spare time!
I pulled up along side at 70 and waved and waved and waved... He was in a world of his own, looked like he was listerning to phil collins... :dry:
Sometimes you need to be a bit more patient with the elderly...
Spotted 83CKS in The Valley carpark again!! It's amazing I think your alarm was probably the only one that didn't go off when I drove past. Was gonna stop and leave a msg, but you might have thought me a stalker so I didn't!! Looked clean.
Peace.
Spotted numerous other skylines as well....no one waved....ghey.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
