Purple R33 GTR with SAU stickers that went into an apartment on sir fred drive near UQ and then came out later, up the street and did a U turn at the roundabout. I was one of the guys in the high vis vests doing the Traffic noise measurements across the road. Waved but My car wasn't anywhere nearby so i probably just looked like some angry uni student who was upset about his noise measurements.
Also saw a pair of white r34's coming and going around the multi story there.
Edited by sneakey pete
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
