followed a 4 door 32 gts-t from noosa to cooroy on my way home from work today. had a cage, exhaust was just about scraping on the ground and i'd possibly suggest getting a wheel alignment as the drivers side rear wheel looked to have a bit more camber to it than the passenger side. could just be my eyesight though.
spotted a R33 driving through the 5 car pileup on the M1 tonight at wooloongabba ??
we were the silver 4 door parked just at the start of it, thankfully we pulled up in time
    • Holy hell! That is absolutely stunning! Great work!!!
