My advice is to stay well clear of keep left signs late at night if you don't want to need to replace your bonnet! :uh-huh: *Trying to learn from past mistakes...*
At Least it was a good excuse to spend a ridiculous amount of money on mods... :)
Yeah, I have been looking at that s15 too, looks like a drift special straight from Japan. Hey Moggy, whats the finish like on that bonnet, I have been looking at those bonnets on there website for a while now. Which one did you get? Last time I was at their shop they were pushing hard for me to get one but, no money and didn't fancy carring one home on the plane! They look very nice though.
Hi, just dropping by lookin at all the sweet sweet skylines....*drool*
well im always looking out for them whenever im driving about around the Tweed/Gold coast areas. Saving for my very own skyline. The thought of one just makes me need to change my pants. *blush* heading up to brisse on sunday to wander the streets looking at the pretty cars ^_^
anyways hopefully ill get one by the end of the year or early next one. But someday ill get it! ;)
Saw a couple about a month ago parked one maroon skyline near the casino i had a nice look at forgot what model heh ^^; But still always nice to see some go by ;)
well might go play some Inital D at Replay. played it last time and now i must play it more! lol but not ganna spend to much on it cause i want the real thing ;)
I thought the finish was excellent - a lot better than I thought it was going to be, in fact. Very glossy, and you can't see any break lines in the fibres where they used more than one sheet (if they did). I got the one they advertise for the series 1, with the vents over the radiator and above the turbo (fair bit of heat comes out of that one). I actually had to wait a few weeks for one to be available cause they sold out and were waiting for a new shipment. They said that they go pretty quick - don't know how accurate this actually is...
I think they're pretty good if you can justify the price (they definitely look best on a white car, I think) but I can tell you that since I got it (only a week ago) I've been stared at by every single copper I've passed regardless of what they were doing and I think I'm going to be pulled up a LOT more than usual (which is not very often at all). :P We'll see...
Someone organise a cruize soon if not i will.KIf no one posts a thread let me know i would like to see a crew of us out at willowbank .Cmon dont be scared.I know some of you are we are all friendly and no one is going to laugh at your times?if anyone is keen put them on here.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
