was neone on here parked at the corner of rafting ground road and moggil road in brookfield this arvo around 5ish, if so really nice 33, nizmo 400r front bar and carbon bonnet, looked really nice.
I saw a white 33 with 400R front bar and carbon fibre bonnet on the big roundabout around the Ford dealership on Moggil Rd at about 12:30pm. Very nice, wanted to get a closer look at that bonnet. Anyone from here own that.
There's a White S2 33 GTT parked behind me at the Novotel Today... belong to anyone here? has a 33 GTR rear wing, and 17" IndyR rims...
Damn your car's low :D I though mine was dropped as far as it would go, but it's interesting to see the two cars next to each other.
Also I parked next to a wine red 32 GTT out at redcliffe yesterday about lunch time. anyone?
Yeah, that was me... Is yours the black one with the stealth rear spoiler? If so i've seen you round that area a few times. Nice car - love the black lines... :)
And that was me too... ;)
I remember seeing you. Gave you a wave as you went past. I'm always out and about in the Indro - Kenmore area so say hi if you see me. Just got a new computer, boost control and fmic so car is running pretty well!
A couple of weeks ago I saw an R34 GTR driving along Moggill Rd in Kenmore late at night... Beautiful car, not sure of the colour as it was dark but think it was red (maybe?). Definitely a GTR though as it had the pumped out guards. Anyone seen it around?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
