well i already have 280kws on 14psi, its not a daly driver, but i wnat to install cams abd be tuned from mid range power and touque. wont gain any more power as such but touque i will. not sure if its safe or not. i have bigger radators and a oil cooler for safety.
im getting examples on other sites on cars making up to 310kws on stamdard bottom end and still going.
this site would be the best for the info so, come on guys.......
xoxoxoxo
https://www.sau.com.au/forums/topic/192298-rb25det/#findComment-3456694
Dyno is a key thing to note when looking at power across various sites around the world.
US is a bit higher (depending on the brand used)
HUB dyno's are much much more generous and people quote as "rwkw" but its not really that at all when you see '300rwkw' only slip 110mph.
Thats in comparison to the Dyno D's that are here.
So any of them could be right i guess, its just that from what ive seen the DD 'generally' are lower than the US brand they use, and when people talk hubs i just look at rpm/boost as the reading means nothing to me
https://www.sau.com.au/forums/topic/192298-rb25det/#findComment-3456706
hmmm you could always do WMI? at the end of the day it will also come down to how you drive it how it is tuned, but still the shelf life of stock bottom end is shortened as explained by nismoid. its a gamble at most, and would never as such hurt to do a compression or leakdown along the way to check on things. There was a few examples of people pushing to see how much it will take to break, and there are a few examples of people with stock ends as well at that power.
But i guess safety sake, always atleast have that budget for the "Just in case" if you are willing to take the chance. You might be lucky you might not.
https://www.sau.com.au/forums/topic/192298-rb25det/#findComment-3458167
The most powerful stock bottom end RB25 I have been in/come across is this one - has cams and thicker head gasket, stock from HG down. Made 450rwkw (~600whp) on a pretty high reading dyno though I reckon it'd run over 500whp on most sane reading dynos. Here's a video of it running a 10.6 with full interior, pump gas and a set of drag radials:
Trap speed etc seems not the best, but they were being a bit gentle with the gearbox etc - remember, all stock bits.
https://www.sau.com.au/forums/topic/192298-rb25det/#findComment-3458447
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
