Hey all just popping in real quickly again to ask the opinions of the forum. Car is a 95 gts-t with fmic, pod with cai, 3.5" turbo back exhaust split dump, running 12 psi with an ebc, always run 100 ron fuel, plugs gapped at .6 or .7, stock everything else and afc neo. Now I was watching my afr's the other day at full throttle and without a tune on stock ecu the reading I got was never below 11 is that common for a skyline with these few mods? Now I'm thinking the readings are definately off cause while at idle I never get anything below 16 just want to confirm that the wideband is stuffed, when at full throttle I never get anything below 11 and I had the wideband exposed to exhaust fumes and heat for like a week before I got power to it. All help is appreciated and welcomed. Thanks again in advance. Also a friend of mine has a ca18 that he wanted to get 300 - 350 rear wheel hp out of and I was wondering if you guys could help out or point in the right direction car is virtually stock and its an automatic.
https://www.sau.com.au/forums/topic/192302-is-this-heard-of/
it cant hurt to get your readings checked against a calibrated 5 gas analyser.
Also those WB02 sensors are very sensitive to exhaust leaks.
Unless your exhaust sytem is 100% sealed then your readings are worthless
I think all skylines with stock ecu's do it once you add boost, thats why so many people get s-afc's to get that extra power, mine runs down to 10.5ish on full throttle!! although I haven't run it again after putting in a new 02 sensor. but I wouldn't stress about it mate >_<
Silly question here.. is the AFC actually tuned?
A tune of the AFC would resolve this... being thats what they are used for
Nismoid thats why I am asking the question, not silly at all ,I'm thinking its a bit high for an untuned skyline on stock ecu.With the mods I listed thats a whole lot more breathing room for the engine so I was expecting 10's at least, another mod I forgot to mention is a bosch 040 fuel pump recently installed like 3 months back, also fpr with gauge and stock pressure reads 44 psi at idle without vacuum. At idle also the widebands reads and shows nothing less than 16 and goes all the way to lean as the car warms and in closed loop mode still nothing less than 16 just was wondering if this is common or can I say the wideband is stuffed come on you don't find this a bit strange. Now i can't say my exhaust is perfect but there are no leaks I can visible hear or see.
I think a few people have missed the point. The 02 sensor should be keeping the AFR at ~14.7 in closed loop as Fat is saying. Usually it would be a bit richer at full throttle also.
Most likely either:
1. Stuffed measurement device (AFRs its reading are wrong)
2. Stuffed fuel pump
3. Stuffed Fuel pressure regulator (check fuel pressure at rail at idle)
4. Stuffed O2 sensor (Doesn't explain only 11:1 AFR at full throttle - usually would be richer)
4. Stuffed AFM (less likely)
Edited by benl1981
if you want good ratios, you need a tune.
02 sensor has little to do with it most of the time. thats why some people run it without that feedback. also the ratios depicted may be inacurate depending on where the wideband is installed in the exhaust and the piping size. any leaks (which many cars have) makes it even more "guessy"
11s is not that rich anyway
That's what he's saying - he expected it to be running richer than that. Mine was in the 9-10s when I upped the boost which is usually how they go.
O2 sensor is what sets the AFRs at light load and idle. In fact I can drive around town in closed loop most of the time if I baby it round. The tune has to be close to the mark first but then the 02 sensor will bring it back to 14.7 AFR by playing with the injector duty cycle.
Take it to a dyno and pay $50 to get it checked there both on idle and full throttle, then if its the measurement device you havent wasted your time trying to fix a problem that isnt there.
Edited by benl1981
Most likely either:
1. Stuffed measurement device (AFRs its reading are wrong): Really think so either the wideband O2 is stuffed or there is a leak in the exhaust cause I did all the test on the device to troubleshoot it and everything was spot on
2. Stuffed fuel pump: Brand new bosch 040
3. Stuffed Fuel pressure regulator (check fuel pressure at rail at idle):44psi
4. Stuffed O2 sensor (Doesn't explain only 11:1 AFR at full throttle - usually would be richer): Maybe read that if you have them connected without power to it might stuff it up and i did for like a week thats the wideband tho have a narrowband on the way that I will install ths week
4. Stuffed AFM (less likely): Could be but doubt it
:Wish I could but dynos are rare over here would fix a whole lot of shit but have to wait a month before they bring the dyno back!!! :rolleyes: You all know how it is once you get someting you want it perfect right away just don't have the tools man so I gatta eliminate stuff on my own really think its a leak tho with the seal around the gaskets of the decat pipe might be my mind but think I can hear a little air escaping will get that siliconed also the dump pipe area and move the wideband O2 sensor to just before the deact pipe tis weekend and see if that fixes it.
Hey Thanks all found the prob as you stated they are very sensitive to exhaust leaks. There is a hole the size of my finger right above the wideband O2 sensor bung half assed welder didn't weld it properly. Gonna get it welded shut on the weekend hopefully this person does a better job and I can finally tune the car properly.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
