  • Replies 47
If you use water to air, you have a chance.
If you say get a 5L cylinder (put it in the boot) and place a spiral copper coil in it, and pack it with ice. Then with the water passing thru the copper tubing in the bucket as well as the heat exchanger in the front bar, you can get great effeciency out of a water to air for dyno runs or 1/.4 mile runs.
Plus you are able to run an extremely short inlet tract, as little as 250mm long for improved throttle response.
...oh and never listen to engineers, they know just enough to be dangerous:D (especially mechanical)
Well i disagree with the engineer even though my dad has been for over 35yrs. you can and i have seen it.
a mate R31 turboed with HKS coller 600x300x75 and HPC coated piping normally has the intake temp at 18deg. and this was on a 27deg day. you should see what its like when we were pushing the car in a 9deg night the intake side said 4deg.
now you think how does he know its right. well its running a Wolf and the programer from wolf thought the temp sensor was broken so he replaced to find the same result. HPC coated piping rocks and gets insane results like this.
cheers Dave
To be honest I don't get that.. How can the air pass through the engine which is internally very hot, be combusted, and come out the otherside actually colder than it went in?
Also, as air is compressed it heats, simple physics, there probably is a formula attached too.
There is probably a good explanation about why it is happening. Whatever the explantions is tho - it wont be defying the second law of thermodynamics.
Where is the ambient temp measured?
Where is the intake temp measured?
Predator, were not talking about it going through the engine. the air that is compressed had no contact with air that is from the engine. and yes there is a formula but there is not point telling anyone cause it will just look like letters to everyone.
as for my mates cooler i have no idea how the **** it works. all i know is that if i had the money i'll HPC coat everything that i could
Dave
Let me qualify my response - i was talking about no water cooling, liquid nitrogen, dry ice etc etc. The velocity that the air passes through an air to air intercooler means that there is no way that the intercooler can heat xfer fast enough to get down to ambient. PS yes i like to break stuff :(
Break stuff or not this does work and its working at 21psi.
and the temp sensor is located on the intake pipe above the rocker cover.
if HPC coating is just insulating stuff how come its used on drag cars, military aircraft, race cars, space ships and it does a little more than insulate. it lets out heat but not letting heat in.
Dave
Ronin 09 - I guess the other qualification you need is that the intercooler has to be small enough to fit into the car as well :(
ok HPC used as a broad group of products does not just insulate stuff. There are different of coatings which are designed serve different applications, ie
* Insulation
* Corrosion protection
* Reduce friction
* Retain oil
* Shed oil
* Look nice
In intercooler pipework applications, the coating prevents the (relatively) hot engine bay from transferring heat to the cooler charge air by acting as an insulator.
So the temperature sensor you are calling ambient is not measured at a point external to the car?
So it measuring the ambient temp and that is what is going into the turbo or a little hotter and what the temp is when it gets just before the t/b. and just as the original post asks it is taking the ambient temp and making the compressed air colder than the ambient.
Sorry R31_IceMan have a chat to your dad, what your saying is impossible.
A more likely explanation of what you friend is witnessing is that he is using a cheap thermocouple, Tandy or something that is out of calibration.
Do me a favour and submerge the intrument he is using to get inlet temps in a beaker of warm water, and then cold water. Check its readings with an accurate thermometer (get one from the Chemist)
My money is on the fact that the instrument he is using to read inlet temps is way off.
Also as browny said, the HPC coated pipes external temp will differ quite an amount from the internal air stream temp.
If we are talking about an air to air intercooler, then it is physically impossible for the post intercooler air, to be at ambient temperature, unless the turbo is in backwards and is decompressing the air. No air to air intercooler is 100% efficient, so it can't happen.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
