hey, yeah newbie asking question. My alternator is making a funny noise. I got the mechanic to check it out when i bought my car he said it was fine. But yeah its making a funny noise. What is the worst case scenerio that could occur. Alternator fcuking up the engine or turbo??? I'm totally new at this and learning. please explain in detail if possible. thanks - how much to get a new alternator too btw - fitted?
(this is my 1st car and I'm learning) - Yes yes I know I'm stupid, dont have to tell me that. :)
https://www.sau.com.au/forums/topic/19232-alternator-fcuking-up-car/
your alternator recharges the battery, if it is broken it wont rechage the battery hence you wont be able to start your car after a while etc etc.... and it wont run right....are u sure it is the altenator? there a many things in the engine bay down there??? :confused:
Bryan i suggest you just leave it for now. i remember u said that if u left ur lights on the batery would die. it may be the battery but it also maybe the alternator not charging it as akeenan said. The alternators in 33's are pretty weak if your one does go bust i suggest u look at gettin a bigger unit or else asking wreckers. The noise is coming from the alternator, a new alternator could cost anywhere from $100-$1000, my dad had to get a new one for his MG and it cost $480, but your car starts where as his didnt at all so yeah you should be right for a while yet
Worse case scenerio - if the alternator goes, beside not being able to start the car, could it do anything serious damage? Any recommendations on batteries i should get? I'm kinda strain on budget so I might have to visit the local wreckers AGAIN for a battery.
I got a new Century battery for mine 3 weeks ago for $65 and comes with 3 yr warranty. If you know anyone with a multi-metre just hook it across your battery, engine off you should have about 12 volts any less and your battery is dead or dying, engine going with a few revs, should be about 14 volts, it not, your alternator is dead or dying. Apart from not charging your battery a dead alternator cannot do any other damage.
tru tru.$65 whoa. Supercheat has their shitty brand cost more than that, and only 1 one year warrant.y WHERE CAN I BUY THAT CENTURY ONE FROM? Please post or pm me place or contact. I'm very interested. thanks
and yeah the noise from the alternator is giving me the shits!
Hey
just wanted to note that my altenator makes that noise as well, seems to get louder as i switch on headlights, fogs etc, plus, my friends Z32 makes the exact same noise...
I should get it checked out sumtime but apparently, its the bearings in the altenator, according to someone i cant remember :P
Oh yeah
n when my fan is working, either the belt, or bearing, or something in the system makes an annoying sort of squeeky noise...very annoying if you are on the spot, in a quiet place..
My alternator sounded like it was about to pack it in more than a year ago, and sounded bad leading up to that. Sounds ok now, no idea why.
Bryan -- get under the bonnet and look at whats connected to what, there is no wiring going to your turbo, so theres no way the alternator could stuff it!
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
