Hi guys, i have a R32 GTR and ive just received my apexi power fc. Just wondering if someone can enlighten me on where the standard ecu is installed in the car. I would like to install it myself then send it for tuning to save a few bucks. Also if anyone can recommend a good shop to take it for tuning.
Regards
Stu
https://www.sau.com.au/forums/topic/192329-installing-power-fc/
Realistically, you won't save yourself a few bucks by doing the installation yourself as fitting the Power FC takes all of 2 minutes. Your factory ECU is located behind the passenger side kick panel and its a simple matter of unplugging the loom and removing the factory ECU, and replacing it with the Power FC.
Bare in mind the Power FC is shipped with only a base tune, and you will be tempted just to plug it in and drive around on it but this is not recommended.
If you can control yourself and your right foot until you have the car tuned, you should be fine, but if you are the sort of person that likes to drive the car hard at times, don't risk it - Take the car, and the Power FC to your tuner, and let them take care of it.
There are plenty of good tuners around, but recommending one for you is hard unless you actually tell us where your from :D
Regards
Stu
This page should help
But if the ECU in a 32 is in the same place as a 33, it'll be on the front passenger side under the glove box inside the car (not in the engine bay)
Just remove the plastic cover where the passenger's feet go (a bolt or two) and you should find it sitting there :D
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
