  • Replies 142
Posted Images
wow that went really smoothly,
i was secretly expecting delays and the like..
do you know if we got the orange or the black?
cheers
Karl
if you only knew what happened my end! some strongly worded but polite phone calls from me requesting updates, confirmation of fund transfer, shipment date - etc.
i've requested the black for everyone, if we get it then bonus - if not then it'll be the 'coby orange'. it just depends if they have any paint in stock.
i have called coby directly and asked them what paints they are using. they have told me that they ARE NOT using HIGH TEMPERATURE paint. the paint is merely for rust, storage and aesthetic reasons.
i personally advise everyone to strip the paint back and go over it with caliper/high temp spray cans or get them hp coated like i have. leaving the coby paint shouldn't do any harm either.
please be patient with christmas delivery. some of you guys might be lucky and get them early, some might get them in the new year.
regardless all buyers have always received them.
I wish i had mine today i was really hoping to get them :P . i really hope now there here wednesday beofre i go out of the counrty ;) so there black thats good to hear merry christmas everybody hope all goes well for everyone
hey got mine fitted today went on sweet took away alot of the rasp i used to get about 2500rpm-3000rpm.
just want to know hwat type of setup are people running on there car mine is just stock with the extractors my stock pipe is 2.5'' so i didnt have to change that
You will all have to tell me how your extractors go guys, mine are still sweet, glad i got HPC coating, just wondering i got a hi-flow cat on my system, do you think i would be losing any power considering its a 3" cat, he just downed it to my 2.5" system i got, would i have got any power increase at all?
Also gotta get it fixed, either the muffler or cat is rattling under there like a B&$%#. Does anyone notice a sucking noise from extractors, or air noise?
Also any difference in havin a resonator or muffler on your system, he put muffler on before the cannon, but last system i got on my old car he put a resonator, sorry im a noob
  • 1 month later...
Anyone thinking of starting this group buy again? I need one :) its $345 to deliver without a group buy mmmmmmmmmmmmmmm.....................
I'm in for sure if theres another group buy :down: , is there another group buy for these any time soon???
Yeah ill be in for another group buy?
PM me if we are starting again Eug
unfortunately there won't be another one without significant interest.
as much as i'd like to help you guys out again, i've run 4 of these buys already and each time it has been more money and effort on my part than anything. now that i'm an sauqld exec, moderator and in my final year of uni i have other obligations to fulfill.
if there are enough people to make it feasible then we shall see.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
