  • Replies 142
Posted Images
  • 1 month later...
yeh f theres another gb im in too.. spewing i didnt get in with that last one!
what are the full benefits of the extractors performance? sound? fuel efficiency?
Car revs out better, less flat spots. Gives more performance in the low and mid-range. Sound is changed as well.
As there is no forced induction, you can't push more air into the engine. Relieving the restrictions in the intake/exhaust system is the key to making power.
Larger mandrel bend extractors and HP Coating helps to scavenge the exhaust gasses out of the engine quicker.
Combined with a hi-flow cat and mandrel bend catback system means that the exhaust gasses leave the engine quickly which in turn means more air can get back into the engine quickly. Air + Fuel + spark = Power. Fast air flowing through an N/A engine means more power is made. Jap engines typically make power through revs, so being able to get through the rev range quickly means that real-world performance is improved.
Fuel efficiency ultimately depends on how a car is driven. eg: I can use half a tank in a week, or in a night. It depends on how much right foot is applied.
Hey Guys,
Ok i have contacted Eug and i am just rounding up the people who are still interested in geting a set of coby extractors.
The people that have put a post up here withing the last few months i have sent a pm to and just waiting for your reply's.
Anyone else who is also interested can you please contact me asap so i can give Eug an approximate number for a bulk order price.
Cheers James
Hey Guys,
Cheers James
I may be interested, R33 GTS4 RB25DE. How much would it cost?
i think James is in the process of figuring that one out now. im not sure whether yours will be different, as obviously youl have an extra drive shaft in there somewhere to contend with...
g'day guys... sorry about the delayed response...
i've got a reply back from partsco.
all prices are subject to current exchange rate
we need 10 confirmed orders to get any sort of discount from Coby.
D12 extractors ~AUD$180-190
F124 gasket ~AUD$10-15
HP coating ~AUD$250-260
Shipping (track and trace) to Australia ~AUD$110-120
at this stage, i need 10 PM's with a definite yes to go ahead. once numbers are set i'll require a deposit to lock the buyers in, in previous buys i've not done this - however i've been caught out with people pulling out at the last minute. this deposit is refundable, only on the condition that we do not make the numbers required for the group buy to proceed.
cheers
eug
I am keen for a set for RB20 DE
R32 skyline
So im looking around $325 for a set ?
How many numbers do we have confirmed so far ... Im in talks with
Craig Saunders
Director
Partsco.com Ltd
If we can get 10 or more people confirmed as definite we will get a good discount from COBY ...
Craig has informed me that it is more financially viable to go in the group buy than it is to proceed with my 1 off order , so I may get refunded from my current order and proceed with the group buy ...
but it depends on how many confirmed orders we have so far as to weather or not I cancel my current order and proceed with the group buy ...
I currently have payed $306.25AU delivered to my door
If we can get 10 or more confirmed this number will be a lot less ...
well if your in contact with partsco then what am i doing here??
at this stage there isn't enough numbers to go ahead as what i was initially led to believe. truth of the matter is that this has occurred time and time again over the years and quite frankly it ruins it for everyone - as that's how group buys work.
people who have PM'd me so far:
hr32gts
na_beast
ShanO'
Peza
if we do not get another 6 people then it can not possibly go ahead, if Mick does decide to purchase a once off unit then we need another 7. although if numbers do not pull through, he may need to just do that to get his headers.
remember you guys asked me to coordinate this group buy, i don't mind helping out fellow forum members - but those who said they were interested but haven't PM'd me are letting the rest of you down.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
