Item: R33 GTS-T Gearbox rebuilt with PAR Gearset.
Age: Brand New
Condition: Brand New, never run a km.
Price: $5500 The Lot. $6000 ($5500 without Clutch)
To Fit: R33 GTS-T, R32 Also?
Contact: Ben - Via PM or 0419741040
Comments: Bought the box for my car when i was doing it up, decided to sell my car before the box had even been put back in after rebuild. It was finished about a month and a half ago. All work done by TOP COG so you are free to call them and question the build or quality. Brand new Exedy Twin Plate clutch is also installed, and a C's Short Shift Kit. I've been told box is capable of 700hp or over, so would make for a great Drag setup or high tuned street car.
WILL CONSIDER TRADE WITH STANDARD BOX +CASH MY WAY
Gearbox - Brand new all built by TOP COG
- Rebuild gearbox with Cross Cut PAR Gearset
- 1st to 4th Gears
- Helical Input Gear
- Replaced 3/4 Hub / Sleeves
- Energizer Pad Spring
- NEO 75/90 Oil (Like over $200 for the oil, and i have enough left over after build for a service)
- Exedy Twin Plate Clutch w/Lightened flywheel (700HP Rating)
- C's Short Shift Kit
There was a few other little things done which i can't remember, for any further info just PM me. Thanks.
Edited by Got Boost?
  • 4 weeks later...
why you going to a standard box and trading your straight cut set???
does it have the billet selector forks and output shaft???
if you have detailed pics i will do you a change and cash you way
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
