  • Replies 266
Posted Images
VR ftw. From the factory it molests any RB. Just wait til modified VR's begins raping N1 RB's... :nyaanyaa:
And why are you hoe's comparing a Z-tune RB to the VR???
Yes they're the same HP from the factory but...ready...the Z-tune is the BEST GTR money can buy and now the R35 is out, it will keep up with Z-tune but isn't limited to only 20 freaakin models :) . We can all have one (tug-tug, ahem...)
It's a muthaflippin' miracle! ;)
hahahaha to ALL !!!!
VR38DETT NEW GTR UPGRADE VERY EASY BROKEN BLOCK !!! BECAUSE BLOCK FROM ALUMINUM HAHAHAH :)
NOTE : ATTENTION TO ALL !!! :D
Thank alllllllllll .......LLOOOLLL :)
Where did you get this information from?
How many R35's do you know that have cracked their Blocks?
Dude... use logic. Nissan would not make a fragile Hero Car that they've been building up for 6 years...
ffs...
agreed... vr block aluminium coke can... easy broke fail... rb engine iron block... like iron man... unbeatable
i say we get a RB26 running 500hp on stock internals and put it up against the VR38.
351 Cleveland > RB26DETT, IRON HEAD NOT CRACK LIKE RB HEAD....
PUSH RODS BETTER THAN DOHC....
THANKS ALLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
ffs..
Know will be seen soon!! Do not forget that the Fund Gears electronic malfunction that will cause many, especially if upgrading engine!!!! :D;):ermm:
VR38DETT NEW GTR UPGRADE VERY EASY BROKEN BLOCK !!! BECAUSE BLOCK FROM ALUMINUM HAHAHAH :ermm:
NOTE : ATTENTION TO ALL !!! :)
Thank alllllllllll .......LLOOOLLL :D
Know will be seen soon!! Do not forget that the Fund Gears electronic malfunction that will cause many, especially if upgrading engine!!!! :ermm::ermm::D
Yes soon we will all know the dark secret of Nissan...stinging out on us by using aluminium and not iron...the goat herder from kuwait imparts his knowledge - his deep engineering/mechanical understanding overshadowing a multi-million dollar company staffed by qualified engineers.
Oh nos Nissan! Recall your GTR's before everyone becomes disappointed. I wish I had 4 thumbs so I could give bkc 4 thumbs down :down::down::down::down:
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
