  • Replies 266
Posted Images
everyone needs to lay off on the racially sensitive remarks no matter how narrow minded and stubborn bkc appears to be.
I actually like BKC. he is a good addition to the forum, and challenges me ot understand google translator better every day.
he certainly is good value and adds character to the forum.
i don't think he's using a translator all the time either BB, some of his posts contain common grammatical errors. sometimes they are just as bad as other forum members. ;)
Hello .
Are there opinions, or information which is the best RB26DETT or VR38TT OR is still too early for such a comparison !!!??? ;)
Thanks ALL :(
hi,
all engines are, in the end judged on how they do the 'job' for which they were designed. the RB26DETT was designed to curb the dominance of the European engines [porche,ferrari,BMW etc] in Gp1 type racing. this it did very successfully. so by that measure it was a very good engine; it has the 'runs on the board'. it is the heart of the Godzilla legend and it created a cult following around the world. it is a famous engine. the new VR3.8 is designed to compete with the super car engines of the world and on paper, it looks competitive/impressive. but it is still only 'on paper' so in my opinion, it has a lot of hard revs to do out in the real world before it can be compared with the RB26.
let's have this discussion in five years time; if the new engine has created a global cult following, if has been given it's own mythical reptillian designation and doesn't meekly take the Godzilla label to gain undeserved 'street cred', then it will have drawn level with the RB26. now to get past the RB26, I think most will agree, is going to take some pretty serious motoring.
having said that, I have just returned from Japan where I made a point of going to a presentation of the new RB35 and later to the Nissan showroons to view the six new colours. for those that are not impressed with the car after seeing only photos I suggest you wait untl you see it in the flesh; this is a seriously beautiful and muscled-up car. also sat down and watched [in the showroom] the video of the car's Nurrburgring trial; powerful!!.
regards
Sorry for the long post.
RB26dett:
Sand cast iron, closed deck engine block
As already stated inline 6 (&V12) engine layout has perfect balance, and is even firing.
Some inline 6 engines do have torsional vibration problems due to length of the crankshaft, but this can be overcome with good design.
VQ35de
High presure die cast alloy, open deck engine block with cast iron cyclinder liners.
60 degree V angle. A 60 degree V6 in even firing (unlike a 90 degree V6 which needs splayed crankshaft journals in order to be even firing)
But a 60 degree V6 still has end to end vibration.
for more info on this try http://www.autozine.org/technical_school/engine/smooth1.htm
The open deck engine block is weaker than a closed deck engine block. However VQ's have been reliably boosted, proving how strong this design can be if designed and manufactured properly.
High pressure die cast engine blocks can also sometimes have problems with porosity.
VR38dett
What we know:
alloy block, plasma coated alloy cyclinder liners
95.5mm bore, 88.4 mm stroke
The engine could be a VQ35hr (or VQ40de) engine block with different liners and rotating assembley.
Or
As stated the engine is said to be based on the racing engines.
Modern racing engines tend to use the lost foam casting method. This method is very accurate with complicated shapes, is consistant and parts tend to have better finish than sand casting (also no chance of a stray sand particle going though your oil system) Lost foam also has the advantage of lower tooling investment, allowing production to be more flexible.
So if the engine really is based of a racing we are talking about a very very VERY serious piece of kit.
BRING IT ON
Cheers
P.S. I do also mourn the end of the inline 6. L28 with twin SU's and extractors sounds soooooo horny
thats funny, Edwin happens to know a few things, and one of them things Edwin knows is, its how many cams you have in your engine, it how you race your coor.
you better learn that......
granny shifting and not double clutchin like you should
you're lucky that 100 shot of NAWWWS didn't blow the welds on the intake.
now, me and the mad scientist gotta go rip apart the block...and replace the piston rings you FRIED
I too mourn the loss...though the idle coming from my Triple SU'ed holden 202 with a nice big solid cam makes me get over it soon enough =D
Now if I can only get the torry registered ....
hi,
regards
Thank you for your reply
YES This is the correct and proper response.
RB26DETT is the best at least for the time being!! Wait and see what the outcome will be the new engine VR38DETT!! Will be seen in the near future!! :P
Thanks aLLL :rofl:
No the V series have already outdone the RB in terms of making outright power, ~2000hp as been made on drag VQ35s. Heat Treatments in NZ *WERE* going to run the motor from the GTR in their 350Z but with research decided that the VQ was a better motor, and they've pushed an RB further than anyone. A stock standard R35 GTR has already hit the dyno and made power which you basically need a cammed, forged, aftermarket twin turbo etc etc RB26 to make which feels gives you a quite laggy car - VR38 looks like its just yawning the power out.
Thread:
http://www.nagtroc.com/forums/R35-Dyno-t20782.html
RB26DETT is the best at least for the time being!! Wait and see what the outcome will be the new engine VR38DETT!! Will be seen in the near future!! :dry:
Thanks aLLL :D
in reply to the statement
Fish coffee has packaging DVD ticket, so bunny banana rain really is speaker. Your shed, grass, 4cam 50 cam 600 cam. Grinding at 19000RPM and making turds at the same time.
Thanks aLL
Thanks aLL
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!????????????????????????????? :wave::):):banana:
guys, it's only really funny to make fun of someones english speaking ability for about the first 5 or so pages. after that it gets less and less funny all the time. trust me on this.
Thread:
hahahaha 350z made for drift loooool you can see DVD SHOCK ENGINE 350Z from japan((350Z COMPLETE SHOCK)) !!
I AM SURE YOU ARE MEAN 350Z COMPLETE AFTER MARKET, BODY ! CHISSIS! ENGINE ! TRANSMISSION .etc .
VR38DETT WILL BE SAME 350Z BUT WITH SOME THE DIFFERENCE,,38 TWIN TURBO etc . lool !!!!
TRUST ME ALL !!!!!!!!!! >_<
Thanks aLL .............. :sorcerer:
Edited by bkc
everyone knows the rb26 is better cause only the rb26 can make a car go around a corner so fast, it starves the engine of oil. ruined bearings is solid proof.
*edit - i vote this thread go to wasteland, so it never gets closed"
steve
"50 weight sounds nice....."
Edited by PHATR32
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
