  • Replies 266
Posted Images
The only thing That would come ANYWHERE NEAR the VR is a Z-tune..
Even then, it would still get is arse handed to it..
or.. would it?
Yes the GTR has titanium this.. bollocks that.. electronic jizz control..
But the Z-tune is still pretty hardcore!..
I mean Nimso poured 5mm of Carbon fiber on the floor plan to stiffen it it..
it uses a the GT500 race engine..
Carbon fiber pannels all round..
10.04 or something like that quarter mile..
Same power.. not sure about torque..
I think the Z-tune is ligher..
The gear changes wont be as quick in the Z-tune as in the GTR.. but.. could a Z-tune make up for this?
hmm.. discuss.. im curious..
Edited by GTS4WD
I am almost sure, I think perhaps if the work to upgrade the engine RB26DETT much better than the engine VR38DETT! !
Because LINE ENGINE IS BETTER FROM V ENGINE !!!!!!!!!
In what way?? Have you seen someone modify the VR38 yet??
And what makes you say an inline motor is better than a V engine??
A 'V' engine is much stronger and stiffer than an inline engine...
Can you back up your comments with facts???
It be appreciated muchly from you.... :thumbsup:
It be appreciated muchly from you.... :yes:
The unfortunately reality is that the inline 6 has probably had its day. The packaging benefits of the V6 makes them a better proposition for the run of the mill car companies - particularly those running transverse installations. Even in longitudinal ones the gains are there in making the car easier to engineer for crash worthiness.
But to defend the old inline six (Which I have a soft spot for) they have the following advantages over their bent up brethren:
* Inherent first and second order balance - the V6's either run funny vee angles or need an extra balance shaft.
* Easier packaging when you turbo charge the motor.
* More room on the axhaust side which allows better cooling for the turbo chargers etc.
* Cheaper head castings as you only need two cam shafts & on head.
* They sound much nicer.
how easy would it be to take out the TT setup and throw in a, lets say T51R SPL onto an engine like that (VR)? Maybe compare it to a 300zx engine...I have never had experience with that...is there enough space...how does it all compare to throwing a t51r on a 26 ?
It be appreciated muchly from you.... :(
I have no experience with the engine VR38DETT to you that expectation proved largely true! !
Despite the dramatic difference in STROKER! !
But in terms of the experience of the RB20DET and RB25DET and RB26DETT is better in all respects use or promotion or maintenance or endurance is much better too! ! !
There is no engine V6 6 Slander advantage proved successful only relatively Tourqu be a little better and I say this advantage! ! !
But respects mentioned above inline much better health and days will prove myself! ! Despite the size difference stroker !!!!!!!
NOTE: inline engine only for the 6 slander !! V ENGINE GOOD ON THE V8 ONLY !! OR MORE!!!
Thanks ALL .[/b][/size] :yes:
Edited by bkc
or.. would it?
But the Z-tune is still pretty hardcore!.. I mean Nimso poured 5mm of Carbon fiber on the floor plan to stiffen it it.. it uses a the 500 race engine.. Carbon fiber pannels all round.. 10.04 or something like that quarter mile..
Same power.. not sure about torque.. I think the Z-tune is ligher..
What race engine are you referring to?
If it's the GT500 from SuperGT, then your probably wrong, cause they have been using a V engine in these for many years in the 350Z and a few seasons in the R34's before that.
If it's the GT500 engine from way back when the R34's first came out( In JGTC), then that's a pretty old engine, and I'd still take the VR over it any day.
or.. would it?
the z-tune costs a lot more and will be a collectors item. The R35 will be mass produced. If I was to chose b/w to two, Id go the z-tune.
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
