Hi all,
Which workshops in the Sydney area would you guys recommend, for servicing and buying parts for your car? The following are workshops I've either heard of or dealt with a little:
Powerplay Imports (Drummoyne)
JustJap (Kirrawee)
Unique Autosports (Seven Hills)
I'm after:
Knowledgeable service and advice
Friendly service
Efficient service and parts delivery
Returns phone calls
Professionalism in working on my car
Reasonable prices charged for parts and service
I know the above things are more or less the same but occasionally one or more of these things are completely absent from one or more of the aforementioned workshops
Any help greatly appreciated
Matt
There's no such thing as a workshop/parts supplier with an impeccable record. Your best bet is to use the search functionality to review the many many other threads that cover the same topic.
Matt, these questions seem to get asked every other week, and almost everyone has differing opinions and their own list of preferred workshops or suppliers to deal with.
The workshops you have already mentioned are all well known and respected, and one of them is a prominent trader on this very forum.
There are a few more great places in my signature which you can add to your list :D
There are a few more great places in my signature which you can add to your list :teehee:
Thanks for the fast reply and the helpful response Blitz
Guess I'm just a bit frustrated with the service from some of the shops I've been to and while I'm not necessarily after a workshop with an impeccable record I just wanted to see what other places people were using and would recommend and you have listed some so thanks, i will check out the other guys you've referred to.
Apologies for asking a newbie question.
Matt
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
