Hey all!
I am not very automotively enclined, so I was after some advice. I am looking for a NEW decent filter for my turbo, probably a pod filter (?). basically I just want to replace the factory airbox in my S2 R33. I have heard Apexi is the way to go. I was hoping to get one by the weekend so I can get it installed this Sunday when I do my service.
So if you guys would be kind enough to point me in the right direction of where I can get one here in Adelaide (preferred) or somewhere online.
I had a quick look at the SAU traders with not much luck.
like I said, I am not very auto savy beyond checking the oil, coolant and the tyres having air in them :D, so any help will be greatly appreciated.
Thanks
Edited by kalel
https://www.sau.com.au/forums/topic/192390-looking-for-pod-filter/
3a racing filter from motoquipe if you want a pod. i think autobarn might have them aswell.
instead of removing the airbox, look into either a decent panel filter, or mount a pod inside the airbox. think about it a bit and youll be able to figure out a way.
if you do remove the airbox and replace it with a pod, make sure you mount the pod somehow, it is illegal to have a pod floating, ie not mounted.
Forget pods, forget K&N (you might as well not have a filter), they're all a waste of time, effort and money for little to no gain.
Make a cold-air-induction if you must, or just wind up the boost for a real improvement.
Yeah I plan on mounting the filter when I install it. From my understanding it improves fuel economy more than any real power advancement.
It sounds as though I will have to look online for one. I have had a look on ebay and a friend of mine told me they have some dodgy ones on there but I will take another look.
No just dont get a cheap shit one, get an apexi one and you will be fine....
Pffft... it'll increase induction noise, that's about it, the rest is cosmetic.
If fuel economy is your concern, make sure your O2 sensor is tip-top, increase your tyre pressure, remove any superfluous weight, keep out of traffic light GP's, and drive economically.
i have a pretty much brand new (only been fitted to car about a week before taken off) K&N POD filter with RB25 adapter. Still in box/wraps (as i said practically brand new).
Throw me an offer if you want (pm) for both the adapter and pod.(You need both to directly bolt on to your car).
Edited by KISIN
no offense to KISIN, but if you're gonna use a K&N pod, you may as well throw handfulls of dirt into your afm.
the Apexi is the way to go according to tests, and the 3A is alot cheaper and still right up there. i'd be choosing between those two.
i wouldnt stick a piece of oiled up foam in my intake. you can if you want
Um Sorry to inform you MUNKYBOY
but K&N isnt oiled up foam.......
You have beeen wrong in the last couple of post u had put up m8
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
