Sounds like they didnt balance is properly down to a 1 degree or less but you would really hear if that was the case and shafts would snap and so fourth take the compressor/exhaust housings off and have a look but if you do and its shattered you more than likely wont be able to put it back together!
Go Otomotos kkr 560 (balanced within 1 degree same as garret/hks but only oil cooled like greddy/blitz turbos) i guarantee you wont go back, similar size to a hks3240 bigger than hks3037
Did a light tune on mine today got 277rwkws on 18psi, standard fuel 91ron unleaded little to no timing, pushing standard fuel lol. Standard motor/gasket/cams.
Hey ur lucky you got to drive your car my gcg highflow blew on dyno couple of months back never looked back since kkr480 and now kkr560 went in. I personally had no probs with the kkr480 even when i ran 40psi for fun only couple of times though!!!.
Plus they just replace it with a brand new one unconditional replacement on the spot what company will do that????
  • Replies 121
Forgive my ignorance but how do you balance a turbo in degrees?
thats wat i was thinking. has to be the shaft that isnt balanced and has let go after some pressure started running through it.
the smallest warp or bounce that the shaft has will be magnified when it spins faster. thats wat makes it loose.
Edited by cheez
not really, may have been a small mis balance. it wont go straight away, will go over time as the balance issue will become bigger. hes only had the car running 12psi for 2 months and then he had it at 16 and 18 for the last 4 weeks or so b4 it went.
ive personally seen the car and the way tony drives, plus if something went through it like dirt, it wouldnt have caused this, would have ceased the shaft not made it shift its balance and bash inot the compressor housing.
Edited by cheez
That looks like something went through it.
If the turbo was out of balance it would have blown up the first time it spooled.
looks alot like the only that that has gone thru there has been parts of the comp wheel itself after if got on a bad angle and started to disintergrate
finally some1 who thinks along my lines, out of balance starts to break up, jams the comp wheel, and finally BOOM!!
Yep, sure does appear somthing has hit the compressor blades.
There is no way to damage the middle of the blades in that manner with just a cartridge failing.
I've killed one and seen a good number of others die, and its only ever the out edge of the wheel that gets minced up and the rest bent. Never chunked up in the middle
Usually its just the outer edge/bent wheel... but your wheel has some nice gouges taken out of the front of it which (more likely than not) is due to something smashing the blades at a high RPM shaft speed
i dont understand how something can hit the blades where theres no way something could have gone in. like i said ive inspected everything. the shaft moves back n forth ,up n down pretty badly
Edited by R33GOD
nothing flew through the blades except chunks of the compressor wheel as it breaks up. check the 2nd pick and see how many small chunks are taken out of the blade. these missing chunks would have caused the damage to the centre of the blades and im pretty sure ull find those pieces in ur cat tony, or in ur rear muffler.
Yeah, but its like what came first.
The Chicken or the Egg. :)
In this case, the middle-area of damage to the wheel would suggest it came first, and the rest of the failure came as a resulting factor... being the middle doesnt "damage itself". Its almost impossible id imagine
If i had i stupid leed for my n80 i could upload pics of my blown turbo the exhaust wheel is crushed and half was in my cat, the shafts where broken in 3 pieces and the core well there was nothing left of it.
And the turbo gets balanced in degrees again if i had a bloody leed i could proove this take ur compressor wheel of any turbo and you will see markings on the inside of the wheel and good quality turbos get balancing also takin off the sides of the wheels just slightly but just enough to balance it to within a degree or less, ring any reputable turbo place they should explain it!!!!!!
You dont just balance it once and its ok you have to do it a couple of times.
Geez i uset to work for the people who make the balancing machines, not just a simple machine anywhere from $250,000- $1,000,000 pretty awesome stuff dont know how they work but i uset to Clean them lol!!!
i beg to differ, i think the damage to the fin on the outer came first, by not being balanced, the edges hit at high rpm, broke away and caused damage to the centre. the more pieces that broke away the more damage to the centre.
therefore: the egg came before the chicken :)
Edited by cheez
Think about 150,000rpm.
something breaks it isnt going to stick around when its being sucked though.
Ive never seen personally the middle of the wheels damaged when the outer edge is only 'shaved' on the housing
Cheez
i agree with you didnt balance it some slacko wanted a smoko and didnt get it till he finished it on the machine so he put it on auto or they did the final balancing by hand and just grinded the wheel cheaply and has someone got a n80 sycronise( not sure if right spelling) leed lol ill look for it dammit and make everyone see what im tryin to explain
if it breaks at the front, it gets sucked in through the blades, but a centrifugal force would be greater than the suction force therefore keeping the parts that break, infront of the blade before being sucked into it.
therefore again, proving my point, edges break, damage the blade in different places over time and eventually causes enough damage to the blade to kill the cartridge.
Edited by cheez
Guest
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
