The Mafia Posted November 18, 2007 Share Posted November 18, 2007 hhmm... maybe thats why they stopped making these... Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3481738 Share on other sites More sharing options...
paulr33 Posted November 18, 2007 Share Posted November 18, 2007 doesnt look good does it Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3481749 Share on other sites More sharing options...
PM-R33 Posted November 18, 2007 Share Posted November 18, 2007 Glad i bought the GT-RS..... Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3481905 Share on other sites More sharing options...
Cubes Posted November 18, 2007 Share Posted November 18, 2007 It would be interesting to know if it were a batch or if slide had some one else do the machine work/balance etc at some point? R33God, you said the motor had a tapy sound or something.. what's oil pressure like? Drop your oil and look for metallic in it. If there's a tap/knock coming from the motor it is possible for the motor to drop oil pressure and as a result starve the journal bearing turbo as they require considerably more oil than the BB cores. Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3481952 Share on other sites More sharing options...
cheez Posted November 18, 2007 Share Posted November 18, 2007 im looking at the garrett cartridge replacements from rotor master in campbellfield. they do a similar job to slide but with garrett ball bearing cartridge and a hi flowed exhaust housinhg. olts straight back on coz it uses ur stock turbo Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3481953 Share on other sites More sharing options...
R33GOD Posted November 18, 2007 Author Share Posted November 18, 2007 oil pressures fine mate. the tapping occured after the turbo blew. not before. it only tapped for a few revs then stopped. engine is A1 Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482388 Share on other sites More sharing options...
Trust33 Posted November 18, 2007 Share Posted November 18, 2007 Chris, dont boost ur turbo past 8psi Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482389 Share on other sites More sharing options...
Al Posted November 18, 2007 Share Posted November 18, 2007 I am not going to speculate what happened. BUT If you are looking for pieces of the turbine or whether "something went through it" i would be looking at the intake to the FMIC or the pipes leading to it. When pieces fly off the front compressor, they will usually get stuck at the fmic, they don't go to the exhaust side . Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482567 Share on other sites More sharing options...
Haysey Posted November 18, 2007 Share Posted November 18, 2007 Looks like exactly what happened to my turbo didnt even last 3months or 5tho kms, electronic boost controller so no overboosting... NOTHING at all went through the turbo wasnt even booting it when it went bang and didnt make boost... im still trying to get a refund.......................................................................... ... Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482605 Share on other sites More sharing options...
discopotato03 Posted November 18, 2007 Share Posted November 18, 2007 One would image that if there loosing blades the wheel is possibly being over sped or surging . I can't say with certainty but many found over the years that compressors with lots of blades like 71mm 8 blade T04's don't like high speed high pressure ratio use . If in that pic it was a complete blade detached from the compressor then its very likely let go at its root and rubbed on the inside of the housing . I reckon that would do all sorts of nasties balance wise and if it managed to jamb between the wheel and housing that would make itself heard . Cheers . Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482710 Share on other sites More sharing options...
Links Posted November 18, 2007 Share Posted November 18, 2007 Agree with Al, has anyone found anything in the IC piping? Looks like 4 of the 7 people with failed ones all had very similar problems.. Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482737 Share on other sites More sharing options...
TazzS13 Posted November 18, 2007 Share Posted November 18, 2007 (edited) Well i got a response from Slide and they basically handballed the problem onto the manufacturer of the turbo for me to sort out....thanks guys! here is a pic of what became of mine....massive shaft play side to side, nothing in the cooler piping and definitely no overboosting! oh and I used 8mm speedflow fittings for the oil feed over the recommended drilling of the banjo fitting :S just so there were no excuses Edited November 18, 2007 by TazzS13 Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3482844 Share on other sites More sharing options...
evil_weevil Posted November 19, 2007 Share Posted November 19, 2007 dam... wonder if I should sell my hi-flow and go something else now... Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483077 Share on other sites More sharing options...
Haysey Posted November 19, 2007 Share Posted November 19, 2007 same with me Tazz.... i sent mine to GCG and got a very interesting report... i think some legal action might be required? Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483132 Share on other sites More sharing options...
SECURITY Posted November 19, 2007 Share Posted November 19, 2007 dam...wonder if I should sell my hi-flow and go something else now... goodluck mate, the bad rep these turbos are getting i'd be surprised if you got a buyer. same with me Tazz.... i sent mine to GCG and got a very interesting report... i think some legal action might be required? same thing here. GCG have printed me out a report on the receipt of the turbo i got rebuilt by them. R33GOD, let me know how far you get with getting your turbo repaired. Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483158 Share on other sites More sharing options...
evil_weevil Posted November 19, 2007 Share Posted November 19, 2007 Joe - you had issues with yours did you? Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483270 Share on other sites More sharing options...
SECURITY Posted November 19, 2007 Share Posted November 19, 2007 yeah mate, click on the link in my sig for all the details. heres a hint... Murnane Motors were the company who REALLY built these turbos. Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483299 Share on other sites More sharing options...
2rismo Posted November 19, 2007 Share Posted November 19, 2007 yeah mate, click on the link in my sig for all the details. heres a hint... Murnane Motors were the company who REALLY built these turbos. Thanks for setting everyone straight as to where the warranty obligations lay. There has been far too much confusion in this thread about this subject. Good job. Cheers. Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483400 Share on other sites More sharing options...
TazzS13 Posted November 19, 2007 Share Posted November 19, 2007 yeah mate, click on the link in my sig for all the details. heres a hint... Murnane Motors were the company who REALLY built these turbos. Thats who I got directed to, going to give them a call and see what they say hmmmm Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483530 Share on other sites More sharing options...
judd33 Posted November 19, 2007 Share Posted November 19, 2007 i have had my slide highflow on my car for about 10 000 ks now,no problem yet!!sorry to hear about the problems people are having with these turbos! my engine needs a rebuild now anyway,will be putting in some good forged pistons and conrods in!will now maybe consider putting a bigger turbo on,will diffnately be garrett!these problems are not good,but some guys have really good luck with highflows,one of the guys in the rb25 power dyno section got 263kw at the rear wheels with the same turbo i got from slide,the max oversize one,so it seems weird that these problems are happening to these turbos,maybe the rush that they had with orders at the start of this year made the people that do the turbos make mistakes with the rush,but that should not happen!!i was lucky i got my turbo before the rush! Link to comment https://www.sau.com.au/forums/topic/192398-yet-another-problem/page/5/#findComment-3483533 Share on other sites More sharing options...
