Is it possible to use the rear wiper mechanism at the front? I was thinking about this the other day. I dont like the rear wiper, so I was thinking of deleting the rear wiper and one of the fronts, and then moving the rear one to the front. Would this be possible?
...why the hell would you bother.
focus your time on something more productive. what is wrong with your existing wipers. why would you intentionally give your car a defect. you wipers are twins for a reason
to repel rain.
let them do their job.
what did they ever do to you!
think how the wipers feel
how would you feel if your wipers converted you over...
...be pretty upset i imagine...
...i would be
to repel rain.
...i would be
LOL love how that descended into total randomness.
please don't encourage him.
if you do this buy a new wiper arm that is bigger than standard this is the single most stupid most regrettable thing you will ever do. worse than getting a tattoo of your ex's name.
No need to discourage the lad, after all if it was'nt for ppl like him we wouldnt be able to check the pics he posts and say "that looks shyte, im glad i didnt waste my money on it"
So go ahead and give it a go, you will be a pioneer in the single wiper blade on a skyline field.
LOL! Weight saving, gold!
But seriously, it has actually been done before, pretty sure GT N1K (Wise sports wide body kit Autosalon isuue 30 something i believe) had it done, didn't look to bad. I love that car so much :laugh:
1 wiper = less wieght than 2 wipers
thats about the only reason i can think of other than being different
And if you go one step further and make it so it stops verticaly it would create less drag, will look like your wiper motor has shat its self but will come in handy for those 250+k/hr runs to the milk bar.
im looking to save some weight too, anyone know any kits so i can run only 1 headlight in the middle and spray the light to the sides??
Nismo would have to have optioned one a 1 stage,
R33 series 2
pm me ROFL
Edited by unarmed_skyline
3 steps to a single wiper arm converstion..
1) aquire said tool:
2) Apply turning disk to passenger side wiper..
3) Take off passenger side wiper off..
Who cares about that one?.. they dont need to see where they are going..
Nismo aint got bollocks on me!
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
