Hi there,
I have a VG30 on my RB20DET R32GTS4. I am now tired of reaching full boost at / after 4,000 rpm and have decided to swap to an RB25 turbo. Searching through the forum I understand that the R34 GTt exhaust housing is the same size as the VG30. My understanding was that the lag was caused by the large exhaust housing which leads me to believe that this swap is a bad idea.
I do however understand that the turbo core and compressor / compressor housing is 'better' in the R34 GTt turbo.
I am interested on your thoughts as to whether or not this swap is worthwhile. After some reasearch I understand that a turbo from an R33 (eithe S1 or S2) will alleviate some of the lag. If the R34 turbo is a bad idea, I will go for a r33 turbo.
Your thoughts?
Edited by Birth
https://www.sau.com.au/forums/topic/192404-r34gtt-turbo-vs-vg30-on-an-rb20det/
mate,
i got an r33 gcg highflow on my rb20det, starts boosting just over 3000rpm and doesnt hit full boost till 4000ish..but comes on hard after that!!!
now i dunno if there is sumthing wrong with my car and ths setup aint right...but thats my circumtances...so im considering chances turbo's to recude lag..i honeslt dont giv to farks about top end...i mean not lose heaps top end ..but i would sacrifice top end for less lag and bottom end.
what ecu u plan on using? im using std ecu with fuel cut defender..not that good to be honest..
Your turbo behaviour sounds exactly like mine (though I imagine yours comes on alot harder than mine). I don't mind my car when I am driving around that suburbs where there is less traffic etc, but I live in the inner west and traffic and lights etc. mean that I am never on full boost and makes the car a bit of a pig.
I will continue using my ecu which is a Tilbrook Auto tune which I modded slightly at home with ROM Edit. I use an old 5-pot Apexi SAFC to make minor changes, but I haven't made any in ages.
i was looking on ebay at those e prom things u can put in ur std ecu? supposively improves ur mid range...and it would be great to get sum of that. besides wats the point of running 14psi when u dont get it till 4-5000 rpm...annoying.
anyone had experiences with these things?
YEh.. one of the r33 s1 or s2 has a nylon wheel which is easier to spool up. my mate has one on his rb20det sylvia boost around 3. I have a sliding performance high flow boost around 4.5/5 grand bigger house in compressor and exhaust sizing witha steel wheel..........14 psi at 5000 rpm....... ANNNOYING
Weird some of you guys have a very laggy VG30.
My VG30 hi flow on my R34 gets to full boost at 12psi at about 3600rpm, making 240rwkw with just that 12 psi. At 1 bar hoping for 250 or more after i get a better aftermarket ECU.
the only reason urs is hittin boost earlier then the other pplz on here is coz u got a 34 which is 2.5 litre, we all got 2 litres so the bigger turbo takes longer to spool.
pplz u just gotta remember that these turbz were made for a 3 litre twin turbo not a 2 litre single, hence why comin on boost late.
the best way for great power and early boost for all the 32 boys out there is to get a HKS 25/10, small but still packs a shit load of a punch.
btw i got vg30 on mine n it sucks for drifting but love it on the road coz the V8 boys think there winning then all of a sudden boom u pass em, mate its soo good lol
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
