Anyone with an R33 S2 must know what I'm on about.
When attempting to clean the dash (the part with the rough surface around the headunit etc), it shreds most
cleaning implements and as a result, leaves tiny little bits of snagged crap all over the surface.
I did use a vacuum and a brush attachment previously, but that really just moved the dust and whatnot around
instead of picking it up.
Has anyone got a method of cleaning this part with effective results?
https://www.sau.com.au/forums/topic/192414-cleaning-r33-s2-rough-plastic-dash/
I know exactly what you mean, it's nice when it's new, but once you start trying to clean it, all manner of crap gets stuck in there. I don't now what they were smoking when they came up with that design.
I use an old damp t-shirt to get the dust off, then go over it with Armourall type spray vinyl/plastic cleaner/protector stuff, again, using an old cotton t-shirt. It comes out pretty mint. I don't like to use protector that makes vinyl look real wet and shiny, I usually go for a product that gives a semi-gloss type finish if ya get what I mean.
I sanded and sprayed mine, so its fairly smooth, so i dont have that problem.
how did you do this? what paints did you use? any specific paint for plastic?
I've givin up trying to clean it
I remember reading somewhere that the S1 dash surround is smooth, is this true?
I'll either get an S1 surround or paint the barstard because cleaning it is a waste of time..
  • 3 weeks later...
one part apple vinegar, ten parts water, the best thing to use is the enjo glove. Well worth the money. Does inside and outside. Wont leave the nasties behind. A light spray of armour-all will finish the job. The more time you leave to soak the more gloss or 'shine' effect you will obtain.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
