Hi,
I'm looking at doing one of the following conversions into my 32 gtst:
a. 26DETT
b. 30/25
c. 30/26
d. 30/20
I am after any information anyone can give me to help me make my decision on this! I intend to completely forge the bottom end (whichever one I will be using) and will use the GT3540 & manifold, Nismo 555cc injectors, Tomei cam gears, Bosch 550hp fuel pump, Malpassi reg, Microtech LT12 (is currently a plug-in but can be used as a wire-up as well) and other bolt-ons that were on my 20. I need to know such things as how straight forward each conversion would be; what mods I would have to do for each conversion to fit (including timing belt, tensioners, water jackets etc. etc.); which head would be the better of the 3 to use (in terms of standard flow etc.); which bottom end would be the better one to use (in terms of strength) and which option will give me the most power with the least cost.
Would appreciate any information at all! Thanks :rolleyes:
P.S. Has anyone ever put a 2JZ into an R32???? I've seen it in an S15 and a Silvia but not a 32!
Budget?
Use of car?
They will dictate what you do really.
As for the whole "3ltr bottom end", there is a thread already on that, and all the possible parts needed.
http://www.skylinesaustralia.com/forums/t15420.html
Basically all the info is already here, you just need to read it :rolleyes:
You could probably do it for half that amount for 350rwkw
If you have an rb26, with a t88, reving to 11,000rpm it will cost you at least $50K to make it somewhat reliable, and it will surely make a shit load more than 350rwkw :P
Just pointing out how ridiculous your comment about "not being concerned about a budget......" was. Everyone has a budget, goal, etc. :thumbsup:
26/30 would be the best convo, i believe only 1 little bit of machining is needed for head to go on 30 bottom end.
a few hidden details about conversion
need to make engine mounts low with th 30 bottom
if running 25 box need custom cross member, tailshaft etc
need speedo drive(can use 32 gtr and just change 33 gear off)
need temp. sensor so gauge will work(put off 20)
new wiring loom
different heater hoses
and a few other things that i may have missed
But yer all the info is on this site
best of luck mate
trav
^^ I used an RB25DE head out of an R32, swapped all the sensors from my RB20 and she fired up and drove on the stock RB20 ecu (well it was a remap with no R&R.. the stocker ecu just hit R&R all the time with more than 10% throttle or 3000rpm). Drove pretty damn well for an untuned ecu running a bastard engine.. just didn't like 6000rpm+ as the afm was maxing out.
Neeed a new turbo damnit! This RB25 turbo is waaaaaaaaaaaay too small, 12psi by 2200rpm but over 5500-6000rpm it gets majorly restrictive to the point that by the 6800rpm limiter it's only making 90hp :worship:
  • 6 years later...
    • Hey everyone, i have quite a few of these now and looking to sell my collection.    There’s many different brands and they all say something similar when powered up. if you would like an example of what they do and how they work i suggest searching JDM ETC READER into google or youtube.    I know some people dont like them but others want that final “JDM” piece for their project.  Below are a few examples of what i have.  feel free to contact me if you want more photos or have any questions. i also have a few that dont make noise but just light up to give the aesthetic.   $80 ea or will do a good discount if multiple are purchased. Located in South Australia and happy to post interstate if required! Thanks for your time!
    • I hope so.  It seems pretty nice. OEM feel the lot.
    • I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done.
    • Ist post I joined after seeing this thread  I have just installed on a r33gtst at first I liked it but I am finding the peddle free play changes …. To a point I have had a zero free play condition and the thrust bearing stayed engaged. I had to back off the adjustment on peddle.   I am about to change slave and fit a braided line to see if I can get a better result
    • I sent off a message to a guy, waiting for his response if he can do it or knows someone.
