I ran the diagnostics on my ecu and it came back with 2. 34 and 54 which are 34:Knock sensor and 54: auto send to ecu or something... 54 is explainable because there is no auto on it anymore. How much will it cost for a new knock sensor, and where is it on the engine so i can change it? Is there just one?
hey i also showed up code 34: knock sensor... so this applies to me as well
what does the knock sensor look like? i'm pretty sure i have no knock / pinging but it shows up knock sensor in the diagnostics
i would have thought this means the sensor is stuffed rather than the engine is knocking... anyone know for sure?
  • 11 months later...
My thing is giving the same fault, im all excited that this may be the reason why my car is overly laggy... had a quick go at reaching the knock sensor, but it appears to be a job requiring jacking up the car and accessing them from the underside of the car
So whats the go, remove the sensor, clean and with some terminal cleaner etc and re-install, or does it typically mean the sensor is faulty.
Removing the plug from the knock sensor is similar to opening a bottle of metho - you need to squeeze the plastic cover in the right place to let it release the "catch". Then the connector simply slides off.
Your problem is probably that the connector is loose, and making an intermittent connection. (The error is due to a short or disconnection of the wire, not from the fact that the engine has "pinged")
  • 4 years later...
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
