Hi Guys,
I have R33 GTST Series 2 skyline. Recently, randomly when i go out to start the car i get nothing. Sometimes i can't even get the doors to open using the alarm remote. Sometimes the doors will open but when i turn the key nothing happens at all. Anyway the first time it did this after playing around for a little bit i found that basically wiggling the wires at the battery terminals would get the car up and running. This has happened maybe 5 times in the last two months. Also twice in the last couple of months i have been driving around and for a split second everything dies then comes back on as though nothing had happened.
I'm guessing that it is an electrical fault somewhere along the line that is causing the above issues. My question is, could an electrical issue like this cause random issues with idle revs. Sometimes the car at idle will drop below 500rpm and bounce between zero and 400rpm and then stall. If i give it some rev then it usually picks itself up again and revs normally again. Just wondering if anyone else has had similar experiences?
The battery was only replaced at the beginning of the year and the connection at the terminal seems pretty solid.
Cheers,
Dean
check for corrosion at the terminals, as well as that it wouldnt hurt to get the battery tested to make sure its not the battery, if all else fails auto elec i guess?
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
