Hi People,
im thinking of going for a turbo upgrade with a garrett 2860R (400hp each). The question is will the stad injectors and fuel pump able to match the turbos? Or i have to upgrade the fuel lines? Will the standard internals able to cope with the new turbos in terms of reliability? Its for a RB26 DETT. thanks for the input.
https://www.sau.com.au/forums/topic/192535-std-fuel-components/
well im thinking of going 800cc for the injectors the extra capacity for down the track and a 044 pump. Hpw about the internals of the engine? Will it be able to cope with the extra power? What is the limit interms of kw that a std engine internals can withstand?
Unless you plan on going much larger turbos later, 800cc serve no purpose.
Motor life
Circuit - 330rwkw (2 years)
Street - 330-350rwkw should last a longer time.
*Golden rule however...*
If you cant afford the rebuild, dont chase the power :thumbsup:
300rwkw seems to never kill the RB26 if looked after correctly and motor is in good health beforehand
well i have no plans for much bigger power. Unless Holden rolls out freaking 400kw commodore or something then i will upgrade to a bigger turbo. Cant let those holdens or fords smoke mee!!!.
I will be aiming for in between 320-350kw@wheels. I even bought a nismo twin plate already to be ready for the upgrade.
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
