Hi all,
I am having big over boost issues with my KKR 480.
If I disconnect my actuator so the waste gate is fully open the car still hits about 25psi at 5000rpm :S...
The turbo is fairly new and the wastegate isn't getting stuck closed.
It makes no sence... you shouldn't really see any boost when the wastegate is fully open.
I had this same turbo on my VS commodore and that didn't over boost.
First time I boosted it with the KKR480 in it I saw my AutoMeter boost gauge hit the stopper so about 35-40psi and it blew one of my silicone joiners inside out when I ripped my foot off the accelerator and this is running with the actuator hocked up with no boost controller.
Edited by Finny
https://www.sau.com.au/forums/topic/192546-stopping-overboost-with-iw/
either the internal wastegate is too small, or your exhaust is too free flowing.
perhaps try a restrictor in your exhaust first, and if that fails, look at an external wastegate setup.
Yes my exhaust is very free flowing, Also jeff please read the tread before replying.
Problem is I want a low mount manifold because I just got my dump pipe and intercooler piping fabricated to suit the low mount but I am pritty sure there is no low mount external gate manifolds about.
I had the same problem as you man, turned out the dump pipe i had on my stock turbo wasn't the right size for the new turbo and the wastegate flap would hit the inside of the dump pipe when it opened and blocked it off. This ment that it would overboost something crazy just like you said. I ended up getting the wastegate pipe enlarged so the flap could fully open.
Disconnect your actuator and then open the flap and listen if it hits the dump pipe before it is all the way open.
Actually scratch what i just said above!
My car is still doing it!!! Went for a spin then with the actuator disconnected and still hits around 20psi!!
I had the dump pipe fixed the other day and the wastegate doesn't hit on it anymore so i thought it was sweet but after going for a test then its still doing it.
Looks like im still in the same boat as you buddy. So does anyone know what F***ing causes this??
Is it that the split dump pipe can't flow enough gases through the 1.5" wastegate pipe or what?
Dude KKR480s have a dump molded into the turbo so that its just got a V clamp back end. It is impossible to modify.
I got my waste gate bored out about 5mm all the way around so from about 20mm to 30mm and it made no difference, still boost spiking like crazy with the waste gate fully open.
Hmmm well i guess in your situation the dump pipe isn't the cause of it. I reckon in my case its the turbulance in the split dump in the place where it joins is that its not flowing into it and causing back pressure through the wastegate. This means that the exhaust gases go the path of least resistance through the turbine housing.
I might try to get an all in one dump pipe with no split, or just make mine into a screamer, which i dont really want to do....
I had this problem when i started tuning my ecu.
With the stock ignition map, the ignition is so retarded that boost is uncontrollable.
I fixed my ignition map and it was sweet.
Could it make it overboost that high from just the standard map :)
I have done some pritty mad tuning with my SAFC II so that this thing spools at 3000rpm I might disable my changes and see how it goes.
I also have maximum timing and a strait through 3" exhaust with a cannon, no mufflers.
I bored the wastegate out my self... but because I didn't replace the flap I bored it out about 1-0.5mm less than the size of the flap which is still a huge difference. I will bore it out further and change the flap and see how I go but I dont think its going to make any difference because the V clamp dump is too restrictive for a larger wastegate hole.
I really don't know why people say that the KKR 480 is a laggy turbo, my car is pritty much stock and it spools it before 3000rpm.
so can having a car running too rich and retarded make it overboost
Ive never heard of this before
It may be the answer to my problem
mine doesnt overboost by too much i can still rev to around 6000 rpm before it boost cuts
Yeah i've never heard of it either Pedro, doesn't really make sense how a car running on a rich and retarded map would somehow cause the exhaust gases to go through the turbine instead of going through the wastegate. At the end of the day exhaust gases are just basic fluid mechanics, go through the path of least resistance, usually being the wastegate when it's open. So to me, any major overboost problem is caused by the wastegate pipe no longer being the path of least resistance, wether it's caused by turbulance or something else?
Has anyone had a major overboost problem, not talking about 1-2psi and found a way to fix it??
This is from http://www.sdsefi.com/
"In severe cases of retarded timing, the mixture is still burning when the exhaust valve opens. Because turbochargers are driven by the energy in the exhaust stream, high EGTs caused by retarded timing produce so much energy at the turbine that even a fully open wastegate cannot control the boost pressure. All in all, retarded timing is counterproductive to producing an efficient, durable, powerful engine."
So at the retarded map with a very free exhaust the wastegate cant flow enough. I had 20psi with stock maps and went down to 7psi with a advanced ignition map. nothing else was changed
If you did have a larger wastegate that would solve the overboost problem as would having more exhaust back pressure.
how did you do it? (ignition map) manuali? or i can fix it by AFC NEO ?? ( i have afc neo) an if by afc neo what settings you did?
Na factory ecu tuning. the last load pont of the rb25det map for ignition is super retarded. If your hitting that point it would cause problems. I was hitting it on the rb25det ecu with a straight pipe and a intercooler.
Its just R and R which everyone goes on about.
Dont have a clue how to tune an afc.
If you bring down the afm voltage you could read of a lower load point i surpose?
Edited by srf
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
