hey peoples
i got a 1987 kc ford laser ghia
1.6 litre carby
needs all new fuses in the fuse box uder the dash
its silver
all plush ghia trim
half custom interior
auto
needs new ignition barrell
needs body work
brand new tyres all round
needs tlc
$500 neg
pm me
https://www.sau.com.au/forums/topic/192577-driftys-kc-laser-ghia/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
