i have just got a profec b2 and i installed it onto my r33 gtst, now i am having problems as it doesnt want to stop boosting at all. I have checked the boost lines and none of them are kinked. i am not sure which way the filter for the boost line into the back of the unit is supposed to be? and also the wires running from the black booster that connects to the intake and actuator the wires for the clip on the back of the unit in the car were off and im not sure which way they are supposed to be? could someone please help?
https://www.sau.com.au/forums/topic/192595-problems-with-profec-b2/
sounds like there has been a stuff up somewhere along the lines.....did u install it yourself or got a import garage to do it....if you have installed it yourself i suggest you take your car into a import specialist garage like boostworx, tilbrooks or somewhere like that...they are generally good with these types of things so wont hurt getting it checked out
ok cool will do was thinking of that cheers mate
I had this same problem with my contoller. I had it prof installed. Took it back and had it checked. Swaped control over for another. It was found to be the control itself.
if u installed it yourself, and wanna save some money before paying someone to find out what you did wrong.
then grab a copy of the manual from the above link and go over it and over it and over it untill you know it backwards
this is what i did when i had a problem with mine... although mine just turned out that i had incorrect settings on the unit.
D1 Garage has experience with these controllers. They use it on there personal cars as well.
Give them a call I am sure they will be able to sort you out.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
