Hi Warspeed, the R34 GTT RB25DET seems to have more adjustment built into the VVT. Is it possible the camshafts are physically the same, but the timing quoted is due to the different VVT positioning?
Hi Sydneykid,
I thought exactly the same thing after typing that last post, there is something very odd about it.
I am thinking that those figures are probably the fully advanced position of the VVT which would then make more sense. Unfortunately those are the only figures I have available and they come without any further clarification.
What are your own general ideas on turbo valve timing ?
Very interesting to see the difference from R33 to R34.
Any ideas why there is so little overlap on the R33 timing? Is this for emissions control, which would not be of as much concern with the R34 due to its extra VVT range? ie retarding at idle/low rpm?
Really appreciate all the info warpspeed, thanks heaps:)
You are right. All modern engines that have to pass idle emissions cannot have more than a very few degrees of overlap, and most run zero overlap these days.
The way VVT gets over this is to retard the inlet cam at idle, so you get zero overlap and clean idle emissions. At some speed just above idle (1500 RPM?) you advance the inlet cam fully.
Because the engine is now under load the inlet manifold vacuum is far lower, and it will stand some overlap without messing up the emissions. The earlier inlet valve closing can significantly increase the low end torque.
At higher RPM (>4,000) you again retard the inlet cam. The later inlet closing will help cylinder filling at the top end.
I have a sneaking suspicion that the R34 figures for the VVT Neo engine give the fully advanced inlet cam timing figure. this might not actually be unreasonable because the engine will spend most of its life between 1,500 RPM and 4,000 RPM anyway. But I cannot say that is the case for sure.
It is important to realize that VVT is put there for emissions, not for performance. If you throw away the VVT and fit a decent inlet cam it will kill the VVT everywhere in the RPM range. Of course if you go totally nuts with the duration it might also just as easily end up worse than stock everywhere.
So the tip is go a bit more lift and duration on the inlet cam and dump the VVT. You can go a bit further on the exhaust side without stuffing things up. If you do it right it will be noticeably better everywhere.
For people still not convinced, they could easily have fitted VVT to the GTR if it had increased performance in any way. Think about it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
