By DraftySquash · Posted
Thanks for that! That is good to hear. I didn't want to try pull something out that should not be pulled out from the block 🤣 -
By soviet_merlin · Posted
The sensible solution is probably to follow everyone else's advice and get something that just reads from CAN and can show anything. But, in similar style as Apexi there's also the Defi DIN gauge kit. They are still making them and releasing new colour schemes. Comes with its own sensors and runs independently from the ECU. https://www.defi-shop.com/products/din/summary_din/ https://www.nengun.com/defi/din-gauge-rhd I have those in my Stagea. Personally I like them because they are good quality clean looking analog gauges that look OEM at night. Reading coolant temp, oil temp + oil pressure. Shows at a glance whether the car is warm enough to boost it or getting too hot and need to let off a bit. Lessons learned with this: - The pressure sensor output can also be split off to an aftermarket ECU. Mine goes to both the gauges and the Haltech - Apparently can't do that for temperature sensors. From what I understand they use specific resistances for the signal and splitting off from it might mess with the readings. -
Anyone got these photos??
I found the Nifty City one. Looks good, has anyone in Oz got it?
https://www.niftycity.shop/products/infiniti-g37-2007-2013-apple-carplay-android-auto-oem-integration
